Author Topic: Custom RGB Keyboard  (Read 2803 times)
Offline dohbot
Custom RGB Keyboard
« on: Sun, 24 January 2016, 17:39:42 »
Hello friends,
How do I make a custom 60% with RGB LEDs, are there only some PCBs that allow for it? How easy are they to program? Also which PCBs that support it also have a non FN layer arrow keys? Thanks!
Offline merlin64
    • MechMerlin
Re: Custom RGB Keyboard
« Reply #1 on: Sun, 24 January 2016, 19:11:26 »
By RGB, do you mean switch LED RGB, or under PCB RGB?
For under PCB RGB the Gon and Winkeyless 60% PCBs make a great board.
I actually haven't seen any switch RGB pcbs yet.
Offline dohbot
« Reply #2 on: Sun, 24 January 2016, 19:28:38 »
Yes sorry, I meant in switch. I'll look into the other two though.
Offline dohbot
« Reply #3 on: Sun, 24 January 2016, 19:29:47 »
I meant something like this: https://www.instagram.com/p/BA6QCBoFWih/
Offline henz
  • What?
« Reply #4 on: Mon, 25 January 2016, 00:28:39 »
here is a under pcb led :)
Offline dohbot
« Reply #5 on: Tue, 26 January 2016, 09:07:09 »
I am selling custom rgb keyboard on ebay.
Check it out !
Are the LEDs per key RGB?
« Last Edit: Thu, 28 January 2016, 05:07:10 by ghostjuggernaut »
