Author Topic: Heart break - One dead key :(  (Read 6065 times)
Offline ocdonkb
« on: Thu, 26 November 2009, 01:42:42 »
Keyboard gods, please help me save this beauty. This is a Focus FK-2001 I'm trying to restore. It's got clicky white Alps switches.
However one of the keys is dead. I've opened up the switch and didn't see anything obviously wrong(but then again, not sure what I'm looking for). The switch internals looked okay. I even connected the keyboard with the switch exposed, to manually trigger the contact point, still no go.
I don't know if my next step should be try and de-solder the switch? Because I do happen to have some spare ones ready for replacement.
It's a beautiful board, and the clicky Alps white is lovely. I'd hate hate hate to trash this board because of one dead switch.
« Last Edit: Thu, 26 November 2009, 01:46:14 by ocdonkb »
| Filco Brown 87 key | Realforce 87U | Unicomp Spacesaver | IBM Model M | Cherry ML4100 | Dell AT101W | Focus 2001 |
Offline chimera15
« Reply #1 on: Thu, 26 November 2009, 02:01:45 »
Nice, real complicated's.  My 2001 has fakes.  You tried to push the leaf forward with your finger or a screwdriver with it plugged in and it didn't work?
You can open the case, plug it in, and try to use a wire, or clips or something conductive  to connect the offending switch terminals underneath the board to try to see if it really is the switch or something to do with the chip or matrix.  Or better if you have a multimeter with a continuity meter you can just use that to see if the switch is closing.
If you have extra switches of course, it's fairly simple to desolder it and replace it once you get it open.
It's likely it is the switch, the parts do get bent out of shape after thousands of keypresses.  I just had a complicated switch go dead on me out of nowhere on one of my modified siigs that I just did a few months ago.  You can usually get it to work again though without a major operation by taking off the actuation leaf, and putting a little more bend in it, so there's just enough room so that you can just get the key spring back in place.
« Last Edit: Thu, 26 November 2009, 02:16:20 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline ocdonkb
« Reply #2 on: Thu, 26 November 2009, 02:19:41 »
Quote from: chimera15;136401
Yeah, following the diagrams here, and specifically this:
so I used a screwdriver and pushed on the contact point. Still didn't work. But thanks for your suggestion about testing the terminals and using the multimeter, I'll give that a go.
I'll also try to fiddle with the shape of the contact leaf too.
thanks again.
Offline chimera15
« Reply #3 on: Thu, 26 November 2009, 02:26:16 »
Quote from: ocdonkb;136403
thanks again.
Yeah good luck.
Alps boards:
Offline Rajagra
« Reply #4 on: Thu, 26 November 2009, 03:16:59 »
Sounds like a job for a continuity tester. Check the switch and the PCB tracks then decide what to do based on the results.
Offline ch_123
« Reply #5 on: Thu, 26 November 2009, 03:18:42 »
I like that second character on the label for the contact point on the left, it looks like a shower head.
Offline chimera15
« Reply #6 on: Thu, 26 November 2009, 03:33:06 »
Quote from: ch_123;136421
lol
It means mark or spot by itself.
点
pronounced ten
I always thought of it more like a rocket ship that was launching, with a gantry that was aiming to hit a spot. lol
« Last Edit: Thu, 26 November 2009, 03:38:33 by chimera15 »
Alps boards:
Offline imsto
    • imsto.cn
« Reply #7 on: Thu, 26 November 2009, 05:55:55 »
actually  点 pronounced    ‘dee  and’   the last d should be canceld just pronounce that 'an'           read quickly  than it's 点
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline chimera15
« Reply #8 on: Thu, 26 November 2009, 13:35:14 »
Quote from: imsto;136456
In chinese? Interesting.   Ten is the Japanese main pronunciation, which is what alps switches are...
« Last Edit: Thu, 26 November 2009, 14:20:43 by chimera15 »
Alps boards:
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #9 on: Thu, 26 November 2009, 14:18:02 »
I didn't install any language packs on my computer so it doesn't work with all those special characters.
Offline ch_123
« Reply #10 on: Thu, 26 November 2009, 14:21:03 »
Ironically, I only see them in Windows as I have not installed proper Unicode support on my Linux machine. You can see the character we're talking about in the picture of the Alps switch.
« Reply #11 on: Thu, 26 November 2009, 14:30:33 »
They all look like funny little numbers.
Offline Rajagra
« Reply #12 on: Thu, 26 November 2009, 15:11:48 »
Quote from: microsoft windows;136549
Those are the character codes in hex if I recall rightly.
I install language packs now just to avoid the annoying messages you get otherwise. It's sad having to bloat the OS even more, but I gave in.
Offline ch_123
« Reply #13 on: Thu, 26 November 2009, 15:16:40 »
Which browser are you using?
Offline Rajagra
« Reply #14 on: Thu, 26 November 2009, 15:20:27 »
Who? Me? Firefox now, but IE back when I installed the language packs.
Offline ch_123
« Reply #15 on: Thu, 26 November 2009, 15:24:38 »
Ah yeah, I think they might come with Firefox. Either way, on my Windows 7 machines with Chrome I dont need to install anything. Not sure whether it is OS or Browser.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #16 on: Thu, 26 November 2009, 18:28:26 »
I wouldn't be surprised if a current OS shipped with fonts covering a fairly large range of Unicode characters. Anyway, I used to have SM set up to use Arial Unicode MS for UTF-8 encoded pages but somehow SM 2.0RC1 onwards doesn't seem to like it any more, sometimes crashing repeatably.
Offline J888www
« Reply #17 on: Thu, 26 November 2009, 18:45:11 »
Quote from: chimera15;136527
His pronunciation is Mandarin Chinese, the Cantonese would differ (dim), but as you corrected we are both wrong because it's originated Japanese.
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline chimera15
« Reply #18 on: Thu, 26 November 2009, 20:12:15 »
Quote from: keyb_gr;136614
Depending on the unicode your browser may not see the code.  There are special Japanese browsers, and add ins for firefox to read all the types of kanji.
Alps boards:
« Reply #19 on: Fri, 27 November 2009, 06:18:39 »
Maybe Internet Explorer 5 explains why I can't see any of those Japanese characters.
Offline ch_123
« Reply #20 on: Fri, 27 November 2009, 06:32:04 »
Yes. Try using software that works.
« Reply #21 on: Fri, 27 November 2009, 06:34:23 »
Like I'm too stupid to know that...I just don't want to waste disk space on language packs.
Offline ricercar
  • mostly abides
« Reply #22 on: Fri, 27 November 2009, 15:37:37 »
Quote from: microsoft windows;136663
Does IE5 support FLash9 or 10? I was having problems on my old palmtop Hitachi with IE4.5.
« Reply #23 on: Fri, 27 November 2009, 16:08:36 »
I don't use Flash Player since it's what makes all the annoying ads on the Internet work.
Offline chimera15
« Reply #24 on: Fri, 27 November 2009, 23:37:09 »
lol
Alps boards:
Offline ricercar
  • mostly abides
« Reply #25 on: Sat, 28 November 2009, 02:52:00 »
My eyes, the goggles, they do nothing! don't click webwits' video...
Offline chimera15
« Reply #26 on: Sat, 28 November 2009, 03:44:42 »
Those chicks were pretty hot for hippies though. lol
Alps boards:
Offline Rajagra
« Reply #27 on: Sat, 28 November 2009, 03:51:23 »
Quote from: ricercar;136858
Don't go to the URL address shown in the video either. It is NOT the band's website!:shocked:
Offline PRISONER 24601
« Reply #28 on: Sat, 28 November 2009, 03:55:26 »
Quote from: webwit;136770
But you'll miss out on all of the good stuff.
 that was ****ing Awesome.
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline Rajagra
« Reply #29 on: Sat, 28 November 2009, 04:02:17 »
Quote from: PRISONER 24601;136869
QFT. The "noughties" are nearly over, and what have we got to show of it that compares to that? Nothing. What a bland, crappy decade it has been!
Offline keyb_gr
  • Cherrified user
« Reply #30 on: Mon, 30 November 2009, 03:15:43 »
Quote from: Rajagra;136871
Anyone care to enlighten the flashless crowd about the content of said video? @home I have a secondary browser for that kind of stuff, but not right here...
But well, yeah, if you're looking for Real Big Things in pop music, this has been a rather unexciting decade. You've had to look more closely. The majors like to play it safe these days (which could kill them in the long run), and much of the interesting music only finds a place on smallish indie labels. It has been getting somewhat better in the last few years though.
Like progress, good music is not for granted. The second half of the 20th century just happened to be a great time for recordings.
Your new avatar is awesome btw.
Offline itlnstln
« Reply #31 on: Mon, 30 November 2009, 09:29:47 »
Quote from: ripster;137428
And although the vintage folks might disagree it is pretty easy today to get $2K Hifi with a $60 Sansa Clip.
I agree.  While I have heard debate to no end on this (from fairly ignorant folks, I might add), it's all in the encoding.  FLAC and other lossless methods sound just as good as the real thing.  I use the -alt preset method of MP3 encoding for my iPod for portablility.  It sounds about as good as MP3 can with very little compression artifacts (the -alt presets really don't compress much at all).  I keep a copy of FLAC and MP3 for most of my music.
Offline itlnstln
« Reply #32 on: Mon, 30 November 2009, 09:41:50 »
Quote from: ripster;137436
REACT - great addon to EAC. Encodes FLAC and MP3 at the same time and dumps it onto my media server.
I'll have to check that out.  Thanks.
Offline ocdonkb
« Reply #33 on: Tue, 01 December 2009, 00:27:38 »
wow, this went OT like nobody's business. :)
An update on my Focus 2001 fixes... I disassembled the switch, took out the contact leaf(the small piece of metal that pushes on the contact point when you strike down on the key), and found that by manually pushing on the plastic contact point itself, the keyboard engages correctly.
This led me to believe the contact leaf itself was somehow "mal-formed". I slightly bent it a bit, so it's a tighter fit on the switch. Typing on it now, everything seem to be fixed.
Offline chimera15
« Reply #34 on: Tue, 01 December 2009, 04:24:54 »
Quote from: ocdonkb;137683
Awesome! Yeah that's what usually happens :)  Glad it was an easy fix.
Alps boards:
« Reply #35 on: Wed, 02 December 2009, 19:08:32 »
That's probably what went wrong with the 6 key in my number pad.
