Author Topic: Simple Starcraft Keyboards  (Read 8058 times)
Offline mOnion
« on: Thu, 26 November 2009, 02:26:28 »
So as a true internet troll I did a minimal amount of digging through keyboard reviews before immediately registering for my first post.
As a Starcraft player, I only need a very basic keyboard, not a fancy pants FPS keyboard with a ton of macros and the such; just something simple, and CHEAP.
Cheap seems to be the problem. I recently realized that the reason the keyboards I've been using suck is because they don't use the older, more expensive switches, so I started my search for switch keyboards, and found Cherry.
I also searched thru the reviews for Cherry keyboards and found that most of them were ~100 dollars. Which is a bother, since usually I go thru keyboards every 3 to 4 months since Starcraft is hard on the keys.
SOOO I found this: J82-16001 Business K-1 Keyboard
Can anyone vouch for it? It's cheap, and I've looked at some reviews (cnet, etc) but nothing's addressing if it's a good switch keyboard, or a switch keyboard at all.
I hope this isn't a TLDR post, but I'd appreciate the help, TY!
Offline chimera15
« Reply #1 on: Thu, 26 November 2009, 02:36:15 »
reposted.  These are the cherry codes:
G80 - mechanical - MX switches.
G81 - semi-mechanical - rubber with spring return.
J82 - membrane cheapy. Made in China.
G83 - quiet membrane. Cheap, soft.
G84 - mechanical - ML switches.
G85 - scissor-switch. 20% larger keytops.
G86 - heavy-duty membrane. Loud, springy. 20% larger keytops. Responsive keys. Can type softly, or hammer away. I like it.
You want a g80, or maybe a g84.
G80's are out there for less than $100, just takes a lot of searching.
« Last Edit: Thu, 26 November 2009, 02:38:44 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline mOnion
« Reply #2 on: Thu, 26 November 2009, 02:41:10 »
AH basic codes ofc :(
interesting, thx a bunch!
Offline chimera15
« Reply #3 on: Thu, 26 November 2009, 02:49:57 »
Here's some of the rest of it:
LAxxx = linear action, AT connector;
LPxxx = linear action, PS/2 conector;
LQxxx = soft contact (tea axis?), PS/2;
LSxxx = click action, PS/2;
LUNxx = linear, USB connector;
LADxx = linear, USB with 4 downstream ports.
Alps boards:
Offline chimera15
« Reply #4 on: Thu, 26 November 2009, 02:50:27 »
Anyone know what LTxxx is?
http://cgi.ebay.com/Cherry-MX119000-MX-119000-PS2-Touchpad-Keyboard-104_W0QQitemZ390115090294QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5ad4abdf76
These are probably linear, but they're cheap, and better than that rubber dome board.
« Last Edit: Thu, 26 November 2009, 02:52:47 by chimera15 »
Alps boards:
Offline PRISONER 24601
« Reply #5 on: Thu, 26 November 2009, 02:56:29 »
I found a used G80 w/ browns for $12
then a new G80 w/blues for $60
keep chasing that rainbow!
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline mOnion
« Reply #6 on: Thu, 26 November 2009, 03:02:44 »
ya i just found a new g80-3000 for 62 that I'm probably gonna end up getting ~_~
wasnt expecting to pay this much, but hey, its shopping season!
Offline chimera15
« Reply #7 on: Thu, 26 November 2009, 03:08:17 »
Quote from: PRISONER 24601;136413
What was the code on the blues?  LS?
Alps boards:
Offline chimera15
« Reply #8 on: Thu, 26 November 2009, 03:14:17 »
Also, what the heck are MX Gold Crosspoint switches?  Are those clicky?
Alps boards:
Offline Rajagra
« Reply #9 on: Thu, 26 November 2009, 03:18:20 »
Quote from: chimera15;136417
Just means Cherry MX.
Offline mOnion
« Reply #10 on: Thu, 26 November 2009, 03:18:48 »
idunno i was gonna ask you the same thing.
the one i found is LS but it says MX Gold Crosspoint, so idunno wtf that is O_O
EDIT: ninja answered ~_~
Offline ch_123
« Reply #11 on: Thu, 26 November 2009, 03:21:44 »
Those are the official term for the switches used in the G80. The different resistance and tactility characteristics are made by having different components in it.
Offline lowpoly
« Reply #12 on: Thu, 26 November 2009, 04:05:59 »
Offline mmgoose
« Reply #13 on: Thu, 26 November 2009, 04:57:24 »
ok. the keyboard in the pic  (J82-16001) is OK except for three things--notice that
1) the escape and function keys are about 55-60% the size of a standard ansi104 (thus it's going to be more difficult to hit F2 F3 F4).
2) the function keys are also a lot closer to the  the number row which in my opinion is a plus ergonomically but unfortunately is non-standard (which means it'll require you to adjust).
3) it's a cherry dome (uncommon and not exactly as  durable as mech so you'll have replace it after a few years). so either you have to find the same exact layout or adjust again to a new one.
my recommendation:
in terms of layout it's either the scorpius m10 or the realforce 87u. problem is, the former suffers from poor build quality (not the switches though); and the latter is prohibitively expensive.
the best that i can recommend is an abs m1. the layout is standard, the switches are decent, build quality is ok. and best of all is the price: just 50$ (right?).
if 50 bucks is still too steep. go find brand new bundled keyboards from compaq, hp, and ibm (all of which are decent enough rubber domes and have the EXACT SAME perfect layout--by that i mean they're standard BUT the CTRL keys are larger than normal and the spacebar is shorter thus the right ALT key is  a bit closer to the number keys. which means: hotkeying and hotkey switching is a bit easier.
« Last Edit: Thu, 26 November 2009, 05:23:30 by mmgoose »
Customizer Ultimate
Offline mmgoose
« Reply #14 on: Thu, 26 November 2009, 05:29:36 »
Quote from: mOnion;136415
the g80-3000 has non-standard function keys (farther from SHIFT and the number keys), otherwise being that it's a cherry and mech--it should be alright.
Customizer Ultimate
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #15 on: Thu, 26 November 2009, 06:45:41 »
Actually a G80-3000 has a perfectly standard MFII-derived layout. There have been no layout changes since the addition of Windows keys and lowering of the first row in 1996 (and that's a good thing); the F keys are exactly where they would be on any MFII board. The original case design goes back to 1990, though the "new-style" case came out in 1998.
(That's a 105-key German layout. Funny, the beige one seems to be Czech-made with the old-style case while the black one is a German-made one with the new-style case. Never noticed.)
« Last Edit: Thu, 26 November 2009, 06:51:11 by keyb_gr »
Offline mmgoose
« Reply #16 on: Thu, 26 November 2009, 07:03:30 »
well yeah. but even the late 90's ansi104 (filco, costars, etc.--where ctrl, win, alt, context menu have the same shape) is also slowly disappearing although not from mech boards. newer boards are by and large moving towards the bigger ctrl.
Customizer Ultimate
Offline 42.tar.gz
« Reply #17 on: Thu, 26 November 2009, 07:30:41 »
Quote from: keyb_gr;136459
Also, the black one seems to have an ANSI-Layout instead of ISO (bigger left shift). ;)
Currently using: some keyboard
Offline keyb_gr
  • Cherrified user
« Reply #18 on: Thu, 26 November 2009, 10:31:36 »
Quote from: 42.tar.gz;136463
Seems like a case of fruit salad pic then.
Offline ricercar
  • mostly abides
« Reply #19 on: Thu, 26 November 2009, 13:17:16 »
So what's the story on the extra row of keys above the FKeys on this Cherry G86? Can they be remapped easily?
From this auction (I got one in a previous auction, at $9 not $12.)
« Last Edit: Thu, 26 November 2009, 13:19:23 by ricercar »
Offline didjamatic
« Reply #20 on: Thu, 26 November 2009, 13:43:44 »
Select your keyboard (SPOS...?) from the download list, then your OS to download "Cherry Tools" software for your keyboard.  The site says you can map the extra keys with it.
http://www.cherry.de/english/service/download.php
What type of switches does that keyboard have?
« Last Edit: Thu, 26 November 2009, 13:50:44 by didjamatic »
Offline ch_123
« Reply #21 on: Thu, 26 November 2009, 14:56:34 »
actually a g80-3000 has a perfectly standard mfii-derived layout.
MFII layout?
« Last Edit: Thu, 26 November 2009, 14:58:42 by ch_123 »
Offline Viett
« Reply #22 on: Thu, 26 November 2009, 15:33:16 »
I'm a huge StarCraft player myself. I've played on an IBM, a FILCO (blue), and a Dell AT101W. The Blue Cherry's click is a bit annoying, and I imagine browns would be better. I have no complaints about the other two boards.
You can get a Compaq MX11800 (brown cherry), a Dell AT101W, or an IBM model M for less than $30 shipped on either ebay or the marketplace. As long as you have a PS/2 port, these are probably your best cheap options.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
« Reply #23 on: Thu, 26 November 2009, 21:08:55 »
Quote from: chimera15;136416
what was the code on the blues?  Ls?
3000lscrc-2
Offline Rajagra
« Reply #24 on: Fri, 27 November 2009, 03:43:54 »
Quote from: ch_123;136562
MFII layout?
Geekhack equivalent of MILF. :shocked:
(Multi-Function 2 really.)
Offline mOnion
« Reply #25 on: Fri, 27 November 2009, 18:39:13 »
Quote from: Viett;136576
i dont think i have a ps/2 port, but there are like conversion cables to port ps/2 to USB out there right?
also i think the function keys one the Compaq are a little distant for the fact that i use them every 10 to 15 seconds in a 20 min game :/
« Last Edit: Fri, 27 November 2009, 18:41:34 by mOnion »
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #26 on: Sat, 28 November 2009, 07:42:28 »
There is a variety of PS/2 to USB adapters and converters out there. Personally, I'd go with an IBM Model M since they're cheap and last virtually forever.
