Author Topic: How To wire G80-3700 PS/2 Cable ?  (Read 10056 times)
Offline Akamig
  • It's A-ka-meegh, Not AKA Mig.
« on: Mon, 25 January 2016, 08:58:07 »
last week I bought a used/cable cutted G80-3700HQAUS From china, it was great.
and I bought PS/2 cable too, but I'm having problem wiring them properly.
first of all, G80-3700's PS/2 cable is with 4 wires, but my PS/2 cable is with 6 wires.
...what the?!
I don't have any DMM, so I seeked around about pin out of PS/2.
this is pin out layout about my cable,
this is general pin out from wikipedia,
http://i.imgur.com/XGlCGQF.png
...and this is general color table.
As result, I wired like this. and connected to PC.
LED was blinking, but when I touched pcb it was really hot and I accidently got electric shock. spiky!
umm... so I'm pretty sure this is wrong. so can anybody give advice for me?
Not Aka"MLG 360 NO SCOPE GET REKT" either.
http://steamcommunity.com/id/Akamig/
Offline tronbeaver
Re: How To wire G80-3700 PS/2 Cable ?
« Reply #1 on: Mon, 25 January 2016, 09:10:37 »
That first diagram does not look like PS/2.
Offline Akamig
« Reply #2 on: Mon, 25 January 2016, 09:16:44 »
"The PS/2 connector is a 6-pin mini-DIN connector used for connecting some keyboards and mice to a PC compatible..." - Wikipedia
Umm, Isn't it right?
Offline yangdigi
« Reply #3 on: Mon, 25 January 2016, 09:42:32 »
For G80-3700
Black---》GND       3
Green---》+ 5V      4
White---》DATA      1
Yellow---》CLOCK   5
For PS/2 female conector
Keyboard use 1 3 4 5.
Offline Akamig
« Reply #4 on: Mon, 25 January 2016, 10:01:06 »
For G80-3700
Black---》GND       3
Green---》+ 5V      4
White---》DATA      1
Yellow---》CLOCK   5
Oh, then just cutoff 2,6 line and switch black and green wire?
Offline tonny950111
  • valar morghulis valar dohaeris
« Reply #5 on: Sat, 27 October 2018, 17:56:13 »
Hi I have the same weird PS/2 cable contains 6 wires which have the exact colors you showed. And I Googled it, found a useful pin-out diagram which has the same 6 color: BLACK, PINK, RED, YELLOW and GREEN. But i don't know what is RA(+)  RA(-)   DEC stand for. Is there anyone who can give me a help ?
