Author Topic: HELP - Cherry stabilizer wire unclipped from plastic holder  (Read 3531 times)
Offline swornxin
    • Nailed Down Custom Pins
« on: Mon, 25 January 2016, 16:50:41 »
Any way I can get this re-clipped in without desoldering the entire keyboard? I've desoldered all of the switches around this particular one. Photo for reference. Anything I can do here?
Note: The wire is out on BOTH sides, and the other switch is also removed.
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline Homenubbie
Re: HELP - Cherry stabilizer wire unclipped from plastic holder
« Reply #1 on: Mon, 25 January 2016, 17:14:06 »
Needle nosed pliers should do the trick.
Offline swornxin
« Reply #2 on: Mon, 25 January 2016, 17:17:37 »
The black plastic actually broke, and I can't fit a new stabilizer under the plate without desoldering. So I have a long night ahead of me.
EDIT: I actually tested to see if I thought I was going to notice the difference on the key in question, and I couldn't, so I am just going to run my "Enter" with no stabilizer. I think it's the easiest, albeit sketchiest, option.  :p
« Last Edit: Mon, 25 January 2016, 17:51:54 by swornxin »
Offline Corsa1r
« Reply #3 on: Mon, 25 January 2016, 17:56:56 »
Until I get a thinner set of PBT's (that don't rub the stabs on this Co-star-stabilized board), I have been running it without any stabilizers but the spacebar, and I honestly haven't had any issues whatsoever.  It actually has quieted those keys down, which I am learning to appreciate.    :)
Ducky Shine 4 - Mx Blues // Ganss G.S-87 - Mx Browns // Type-S HHKB 45g // FC660M - Mx Reds // FC980M Silent Pink // Aula F75 Ice Veins // Rainy75 MMD Vivians
Offline axtran
« Reply #4 on: Mon, 25 January 2016, 19:42:34 »
Good luck. Hope you don't break the step on the cap :)
MX Silent > MX Vintage Black > Everything Else
