Author Topic: size of IBM M keyboard  (Read 3120 times)
Offline kajedot
« on: Tue, 26 January 2016, 06:26:07 »
Hi!
Fast question: how long is the longest side of standard IBM model M keyboard?
Offline Olumin
  • "Guy walks into a doctor's office..."
Re: size of IBM M keyboard
« Reply #1 on: Tue, 26 January 2016, 06:40:12 »
~ 48,5 cm
Offline kajedot
« Reply #2 on: Tue, 26 January 2016, 06:42:28 »
Thank you  :)
« Reply #3 on: Wed, 27 January 2016, 04:02:34 »
Welcome to Geekhack!
Offline ch_123
« Reply #4 on: Wed, 27 January 2016, 14:42:52 »
To put into perspective - an SSK is nearly the same width as a modern rubber dome keyboard :D
Offline SamirD
« Reply #5 on: Thu, 28 January 2016, 23:59:50 »
Check this out for all the specs--straight off my box.  :thumb:
https://geekhack.org/index.php?topic=76403.msg1908154#msg1908154
Offline klennkellon
  • I like bottoming out
« Reply #6 on: Fri, 29 January 2016, 20:48:24 »
If you are concerned about size, you can check out the Unicomps, they have a Model M with a much smaller footprint.
« Reply #7 on: Fri, 29 January 2016, 20:51:19 »
If you have to ask, it is too big for your desk.
- Plato
« Reply #8 on: Sun, 31 January 2016, 01:53:25 »
:eek:
ch_123 posted again!!1!1!!one!!
