Author Topic: Model M membrane part number unicomp  (Read 2935 times)
Offline i_r_noob_
« on: Tue, 26 January 2016, 17:46:33 »
Disassembled a couple model Ms and the membrane in one is totally trashed.  I'm going to order a replacement from unicomp but am not sure what number they want.  The top layer has xxxxxxx-zzz and the bottom layer has yyyyyyyy-zzz. I assume they want the numbers after the hyphen since the numbers before the hyphen are different on each membrane layer?
Thanks
Offline 0100010
  • Not Sure
Re: Model M membrane part number unicomp
« Reply #1 on: Tue, 26 January 2016, 19:03:52 »
Probably easiest to open a support ticket with them, to discuss the correct part number; then place your order after their direction.
Offline i_r_noob_
« Reply #2 on: Tue, 26 January 2016, 19:15:19 »
Which is what I did last tuesday. And again last night
« Last Edit: Tue, 26 January 2016, 19:16:51 by i_r_noob_ »
Offline ctm
  • Hello, world!
« Reply #3 on: Tue, 26 January 2016, 21:56:54 »
Hmm... they replied to my tickets quite quickly. Usually the same day or the next business day.
Coming:
Ellipse Model F F62.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #4 on: Wed, 27 January 2016, 10:15:08 »
LOL.
All you need is the keyboard model number.  Not the membrane model number.
What model number keyboard are we talking about?
Example: It could be 1391401 51G8572 42H1292 UNI0446 etc etc....
« Last Edit: Wed, 27 January 2016, 21:42:09 by Snowdog993 »
