Author Topic: Any stock programmable TKL's/60/68's with clears?  (Read 3341 times)
Offline iLLucionist
  • Topre is Love.
« on: Wed, 27 January 2016, 05:01:07 »
Are there any stock programmable keyboards with clears that are programmable with let's say multiple layers? How does this programming work? For instance, are there also controllers that allow to program the default layer?
Offline Fiery
  • Click Clack Clock and a nice Thock
Re: Any stock programmable TKL's/60/68's with clears?
« Reply #1 on: Wed, 27 January 2016, 05:04:24 »
Pok3r is a 60% with 4 layers 2-4 are programmable. maybe take a look at that.
TP4 fanboy
Offline iLLucionist
  • Topre is Love.
« Reply #2 on: Wed, 27 January 2016, 05:11:54 »
I should've mentioned this in my original post, but the pok3r has some issues/nuisances I am wary of. For example, people report losing their programmings on firmware updates, no osx/linux support without a virtual machine, led's always on in layers 3-4, and unability to program the first layer, and bugs in firmware.
Otherwise, the pok3r feels tempting but it feels a bit like it's 80-90% decent, but the other 10% is really annoying to live with.
Offline Fiery
« Reply #3 on: Wed, 27 January 2016, 05:36:10 »
well the firmware updating makes sense and how often do you need to update it? not supported on linux and osx? the led could be annoying I guess.
TP4 fanboy
Offline ctm
  • Hello, world!
« Reply #4 on: Fri, 29 January 2016, 16:27:52 »
For true programmability you need a board which you can flash in custom firmware. There were a few like Ultimate Hacking KB, White Fox, KC60, S60-X etc, but there does not seem to be any at this moment.
Coming:
Ellipse Model F F62.
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Sat, 30 January 2016, 02:15:04 »
Input Club K Type, when it's ready.
Offline iLLucionist
  • Topre is Love.
« Reply #6 on: Sat, 30 January 2016, 06:16:26 »
So I was thinking about my ideal 60% board. It would have MX Clear, look like pok3r with high extremely quality components (steel case that doesn't scratch, perhaps even heavier which should be possible if you scrap all components together and solder yourself), o-rings, HHKB-layout, a controller that allows to custom flash so that I can develop my own firmware in C or even asm would be fine.
Basically, I would like a HHKB with clears (or topre), but then plate-mounted and extremely heavy and silent. And custom programming capabilities AS I DESIRE, completely custom. So that I could also program my own layer-1 default bindings.
Hmmm... one can dream right?
Offline ctm
  • Hello, world!
« Reply #7 on: Sun, 31 January 2016, 18:59:47 »
I think the Infinity 60% is quite close. It has a layout very close to HHKB (split right shift and split backspace). It supports custom firmware including TMK. You can put it in your metal case if you get the flat plate version. You can also put o-rings on it.
Coming:
Offline iLLucionist
  • Topre is Love.
« Reply #8 on: Mon, 01 February 2016, 04:47:05 »
Thanks! But where to buy? It has been on massdrop, but I cannot find it elsewhere..
Offline ctm
  • Hello, world!
« Reply #9 on: Mon, 01 February 2016, 07:53:23 »
The drop ended some time ago and it does not seem to be another round soon. You can keep an eye on classifieds. I also took a quick look at GON and FaceW PCB. They both seems to support split right shift and split backspace. They have their own GUI to customize firmware, but does not support TMK unless you flash in new bootloader.
Coming:
Offline iLLucionist
  • Topre is Love.
« Reply #10 on: Mon, 01 February 2016, 09:25:01 »
Thanks! I'll patiently wait.. I've requested it on massdrop already, but so have many.
