Author Topic: Help with pcb , do I need to jumper it?  (Read 1825 times)
Offline Jokrik
« on: Wed, 27 January 2016, 07:01:18 »
Heyall,
Recently purchased a custom board, the solder material on the switches are weird and requires me to do high temp desoldering
Took me a while to desolder and resolder
however I've got 3 switches which do not register upon pressing
I marked it with bolts in the picture, I've been told that I pulled the pads up on one of them
Can anyone help me see if something is wrong or I ****ed it up? and do I need to do jumper?
If yes would you kindly mark it and how to do it?
Thx
Re: Help with pcb , do I need to jumper it?
« Reply #1 on: Wed, 27 January 2016, 19:52:02 »
Looks like you've lost the left pad of the bottom switch (as pictured, next to R58) so jumper that to the square hole above it.  You could try this on the other two as well and you might get lucky...
That's the only obvious fix I'm afraid - it's a double sided PCB and half the interesting stuff is on the other side.  If you can find pics that would help a lot.
