Author Topic: [GB] Cherry MX Lock - ROUND 2 - SHIPPED - EXTRAS SOLD  (Read 66374 times)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
Re: [GB] Cherry MX Lock - ROUND 2 - SHIPPED - EXTRAS SOLD
« Reply #200 on: Mon, 30 May 2016, 12:02:35 »
You don't need lock support in TMK afaik. You just need support for ACTION_LAYER_MOMENTARY().
I wonder if mx locks can be used in most pcb without tinkering?
I plan to use it on my nerd on the caps lock position.
Do you know if it will work?
Offline thelectronicnub
  • drowning in keyboards
« Reply #201 on: Mon, 30 May 2016, 14:27:41 »
it should work since it has exactly the same pins and mount as a regular mx switch. the only thing that probably won't work is an led
KUL ES-87 w/MX Greens
B/S/T Thread
Offline roostrc0gburn
  • its just plastic
« Reply #202 on: Mon, 30 May 2016, 15:04:30 »
depending on the pcb, you might be able to get it to work. pcbs that support full-touch capslock as well as stepped have 3-4 led holes in the pcb. i have not tried it, but it looks like the octagon v2 and zz96 could do it
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #203 on: Mon, 30 May 2016, 15:15:38 »
Oh, it's fine as the nerd pcb has it's own caplocks indicator right beside it.
so an in switch led is not necessary :D
Ahhh okay, I will have a look later. Thanks!
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #204 on: Mon, 30 May 2016, 17:35:09 »
On second check, the nerd pcb does support leds like you said only on off-centered caps lock.
Good thing I'll be using that layout so all in all, it all worked out :D
« Reply #205 on: Tue, 14 June 2016, 14:29:15 »
locking thread since gb has been over for a while now, pm me w/any questions if you've got them
B/S/T Thread
