Author Topic: Keyboard Sleeve question  (Read 4277 times)
Offline tigersharkdude
« on: Thu, 28 January 2016, 20:30:33 »
I was wondering if any of the Sleeve makers have the ability to do embroidery work? I would like to find someone that could make a black/dark greysleeve for a TKL with this on it (without the black background)
Re: Keyboard Sleeve question
« Reply #1 on: Fri, 29 January 2016, 20:17:47 »
Nobody : (
Offline Badwrench
  • ummmm.....I forgot
« Reply #2 on: Fri, 29 January 2016, 20:39:43 »
I can check with my local place and see what something like that would be to put on one of the Chiton sleeves.  What kind of dimensions are you going for?
« Reply #3 on: Fri, 29 January 2016, 20:49:28 »
Tkl sized, for a quick fire rapid, and slightly thicker to keep from damaging the taller artisans
« Last Edit: Fri, 29 January 2016, 20:56:56 by tigersharkdude »
Offline studentben
« Reply #4 on: Mon, 08 February 2016, 17:55:30 »
You could send a message to Specialeemade sleeves, they seem to have decent customization options.
I believe the correspondent here is like dummytim or something in the Artisan area.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #5 on: Mon, 08 February 2016, 18:06:10 »
Did you check with Switchnollie?
