Author Topic: Leading Edge DC-2014  (Read 7354 times)
Offline merlin64
    • MechMerlin
« on: Thu, 28 January 2016, 22:58:55 »
Picked this up locally! =)
I had never tried Blue ALPS before and I like it. My experience so far is that it seems almost linear with a slight bump. I'd say it feels similar to the Orange ALPS on my Apple IIGS except the bump is less pronounced and it's a whole lot smoother. Don't hang me, but they almost feel like a more tactile and smooth Cherry MX Brown. The click is also less audible than Cherry MX Blue.
I looked around online for a 5 pin to PS2 converter, I couldn't find any female ones. Anyone know of any? Or is this a converter I'm going to have to make on my own?
Anyway enough talk. Here are some pictures
126209-0126211-1126213-2
Offline 1deeg
Re: Leading Edge DC-2014
« Reply #1 on: Thu, 28 January 2016, 23:50:12 »
Offline SamirD
« Reply #2 on: Thu, 28 January 2016, 23:57:30 »
Great find!
The converters are quite easy to find in local used computer stores.  I just picked up a few in the clearance section of a local store for $3 each.  :thumb:
Offline ebacho
« Reply #3 on: Fri, 29 January 2016, 02:13:02 »
How about this
http://www.amazon.com/SF-Cable-Keyboard-Adapter-MiniDin6/dp/B0016RTO1M/
This isn't going to work.  The DC-2014 is XT and the one you've linked is just a physical converter from AT to PS/2.  You need an active converter for this.
@OP, I'd suggest buying a teensy and making a soarer's converter.
Offline frogthejam19
  • Good Vibrations
« Reply #4 on: Fri, 29 January 2016, 02:38:15 »
 ;D
lucky dog. willing to sell? ^-^
"All is Well"
« Reply #5 on: Fri, 29 January 2016, 07:21:00 »
You will need to go one step further, a standard Soarer's/Teensy is not enough. Usually there are 4 wires to connect, here there will need to be a 5th wire, "Reset" and I will try to look it up for where it attaches on Teensy. It is buried somewhere in the TL;DR of Soarer's thread.
edit:
https://geekhack.org/index.php?topic=69882.msg1681062#msg1681062
« Last Edit: Fri, 29 January 2016, 07:26:14 by fohat.digs »
- D Trump 2026-10-24
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #6 on: Fri, 29 January 2016, 07:29:35 »
Congratulations on the find! :) maybe I'll run into one someday too.
Many heretics have brutally butchered these for the switches; surely a capital offence. Glad to see you want to use it like it is :) .
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #7 on: Fri, 29 January 2016, 07:37:20 »
I am one of those people
Offline SamirD
« Reply #8 on: Fri, 29 January 2016, 08:39:22 »
How about this
I was halfway thinking this myself, but didn't know if the board spoke xt or at.
GH user orihalcon sells a plug-and-play cable that will convert any 5-din to ps2.  It's not only a cable adapter, but has soarers built-in.  It's a bit pricey, but he offers a discount to orders placed directly and is very plug and play.  Right now he's even got a deal on getting one with a brand new m122 for just a bit more than the cable itself.
« Reply #9 on: Fri, 29 January 2016, 08:45:47 »
Orihalcon's cables use Soarer's firmware but not Teensy breakout boards.
You need to verify with him whether the 5th leg is connected before you try to use it for the Leading Edge.
Offline merlin64
    • MechMerlin
« Reply #10 on: Fri, 29 January 2016, 10:18:32 »
Hmmmmm. That is unfortunate. My teensy's are currently being used for other projects.
Was really hoping to use this keyboard at work, I took it apart to clean it out and I noticed every switch had a diode, so its also possibly NKRO!
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Fri, 29 January 2016, 12:26:02 »
That's horrible! You even took pictures of your poor victim! You sick bastard!
STOP THIS MAN! STOP HIM! DON'T LET HIM GET AWAY!
« Reply #12 on: Fri, 29 January 2016, 12:46:36 »
Me, too. I simply can't stand weird-o layouts, especially when there are such great switches that are generally unavailable anywhere else.
Offline SamirD
« Reply #13 on: Fri, 29 January 2016, 13:06:39 »
True, but from my discussion with him on the one I got from him, it will work for anything AT/XT/terminal and be plug-and-play, which would work for what the OP has in mind of using it at work.
Offline 1391406
« Reply #14 on: Fri, 29 January 2016, 15:54:04 »
That is an odd layout. I don't like it.
Offline chyros
  • a.k.a. Thomas
« Reply #15 on: Fri, 29 January 2016, 16:54:14 »
No respect for precious old things. Humbug. Humbug I say!
*shakes walking stick around*
« Reply #16 on: Fri, 29 January 2016, 17:25:28 »
Don't try and pull that **** on me. I am typing this on a keyboard dated 15 MAR 1985.
When I was born, Truman, Churchill, and Stalin were the principal world leaders.
Offline jacobolus
« Reply #17 on: Fri, 29 January 2016, 18:06:29 »
almost linear with a slight bump [...] similar to the Orange ALPS [...] except the bump is less pronounced [...] The click is also less audible than Cherry MX Blue.
What are you comparing "slight bump" to, besides orange Alps? The amount of tactile feel should be relatively similar to orange Alps, maybe slightly but not substantially less.
I suspect that at some point this keyboard was stored with all the keys held down for an extended period of time, bending all the click leaves slightly out of shape and reducing the click.
The sound of new blue Alps switches is different than MX blue, but in general should be comparable in volume. (Though this depends a whole lot on the context; MX blue switches are a plastic-on-plastic click which makes almost no sound for a loose switch, but can reverberate quite a bit with the right keycaps and case.)
Offline merlin64
    • MechMerlin
« Reply #18 on: Fri, 29 January 2016, 18:29:20 »
LOL, I guess this is why people like different switches
The bump isn't substantially less, but i would agree that it feels like orange alps the most. I think the smoothness is what makes the bump seem smaller.
Offline chyros
  • a.k.a. Thomas
« Reply #19 on: Fri, 29 January 2016, 18:42:52 »
For sure it should be MORE tactile than orange Alps I'd say Oo . Tactile Alps aren't as tactile as clicky ones I've found oO .
You mean the DC-2014 is too modern for your tastes then? :p
Offline ebacho
« Reply #20 on: Fri, 29 January 2016, 18:55:57 »
edit:
FWIW I never had to do this on the Soarer I made.  The DC-2014 was fine with whatever the standard configuration was when I made my soarer.
« Reply #21 on: Fri, 29 January 2016, 19:22:30 »
That is good to know. I tried 3 DC2014s with my outboard Soarer's/Teensy which works fine with IBM F XTs and nothing happened, so maybe I had just gotten dud Leading Edge boards. All the more reason to euthanize them and harvest their organs.
