Author Topic: How to unlube switches?  (Read 8460 times)
Offline Geroximo
« on: Sat, 30 January 2016, 05:23:56 »
Hi,
I don't like the lubed switches anymore and want to unlube them.
The stems are easy to clean, but the inside of the switch housings are a bit tricky.
The only way I can think of are Q-Tips with some sort of cleaner on it.
Are there better ways?
Offline bocahgundul
  • a seal
Re: How to unlube switches?
« Reply #1 on: Sat, 30 January 2016, 05:39:58 »
dip in in alcohol it might help  :thumb:
Offline iLLucionist
  • Topre is Love.
« Reply #2 on: Sat, 30 January 2016, 06:18:42 »
Aren't the switch housings ABS? In other words, wouldn't you slowly dissolve and kill the plastic if you would apply alcohol to it?
Offline bocahgundul
  • a seal
« Reply #3 on: Sat, 30 January 2016, 06:22:53 »
No just clean it with alcohol not dip it I'm wrong  :p
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Sat, 30 January 2016, 06:26:05 »
Depending on how desperately you want absolutely all the lube off you might want to use LPE instead.
Offline Lepidus
« Reply #5 on: Sat, 30 January 2016, 06:44:40 »
I think the housing is made of Nylon and the stem of POM.
Probably PA 66, http://qepp.matweb.com/search/DataSheet.aspx?MatGUID=f697bc3bd284443690e18a44a1b66b05
Offline Bucake
« Reply #6 on: Sat, 30 January 2016, 12:51:24 »
Ctrl Z
Offline jerue
  • (Whenever that happens :P)
« Reply #7 on: Sat, 30 January 2016, 13:10:19 »
Ctrl Z
I hear Alt+F4 is what all the pros use these days.
Offline alienman82
« Reply #8 on: Sat, 30 January 2016, 13:19:28 »
removed.
« Last Edit: Thu, 01 March 2018, 16:18:19 by alienman82 »
Offline iLLucionist
  • Topre is Love.
« Reply #9 on: Sat, 30 January 2016, 13:41:31 »
Ctrl Z
nah nah it's Ctrl+Alt+Delete
Nah... $ killall <proc_name>
Offline alienman82
« Reply #10 on: Sat, 30 January 2016, 13:50:15 »
removed.
« Last Edit: Thu, 01 March 2018, 16:18:15 by alienman82 »
Offline tronbeaver
« Reply #11 on: Sun, 31 January 2016, 09:56:59 »
A match should do it.
Offline jbondeson
« Reply #12 on: Sun, 31 January 2016, 10:45:49 »
A serious answer would be a degreaser and warm water -- just make sure it's safe for plastics.
Just remember that most switches are factory lubed in certain locations (I believe on MX the slider is lubed), so if you get it all off you should reapply a light coat. Otherwise you could drastically shorten the life of the switch.
Offline iLLucionist
  • Topre is Love.
« Reply #13 on: Sun, 31 January 2016, 10:57:13 »
How would completely unlubed swithces drastically shorten the lifetime of a switch?
Offline jbondeson
« Reply #14 on: Sun, 31 January 2016, 10:59:08 »
Higher friction on the touch points would increase wear.
Offline iLLucionist
  • Topre is Love.
« Reply #15 on: Sun, 31 January 2016, 11:21:07 »
Ah good to know. Interesting, because some people also argue that to get a smoother travel you should completely unlube and then the wear will do away with any rough edges on the slider or housing, which will make for a smoother experience.
Offline jbondeson
« Reply #16 on: Sun, 31 January 2016, 11:26:17 »
I can see running them bare for a while to smooth them out, but only if you follow it up by reapplying the lubricant after a break in period, otherwise you'll continue to wear and change the feel.
The hard part would be ensuring an even wear when doing this method.
Time for a switch pressing robot! :D
Oooorrr, you could buy Gaterons. (But building a robot sounds like more fun)
Offline iLLucionist
  • Topre is Love.
« Reply #17 on: Sun, 31 January 2016, 11:30:18 »
Is Gateron sooo much smoother than stock mx's? Makes me curious to try them out..
Offline jbondeson
« Reply #18 on: Sun, 31 January 2016, 11:35:51 »
Zeal did some great macro shots: https://geekhack.org/index.php?topic=74836.msg1847809#msg1847809
Offline iLLucionist
  • Topre is Love.
« Reply #19 on: Sun, 31 January 2016, 14:11:45 »
Those look damn smooth to me, wow. What to get.. zealio's or gateron's for another experience?
Offline jacobolus
« Reply #20 on: Sun, 31 January 2016, 15:12:19 »
What kind of lube?
If it’s Krytox, you’ll have a tough time getting it off with any common kind of solvent, cf. https://geekhack.org/index.php?topic=58312 (“NO organic solvent dissolves PFPE. it has no flash point (does not burn), it's ridiculously hydrophobic, etc. so there's basically no way to get it off a surface except for mechanical debridement.”) There are solvents for Krytox but they are very expensive and I’m not sure you can easily buy a small quantity.
You could try an ultrasonic cleaner if you can find someone nearby who has one.
Alternately, you could just try to scrape the lube off with a q-tip, or better, a microfiber cloth. I don’t think adding “cleaner” is going to help. If it’s Krytox, neither an alcohol dip nor a “degreaser” is going to do anything.
Other types of lubricant will be easier to remove.
« Last Edit: Sun, 31 January 2016, 15:28:20 by jacobolus »
Offline Prelim
« Reply #21 on: Sun, 31 January 2016, 15:44:43 »
just use a swab to remove 90% of it (sliders included) and you are good to go ;) btw, minimal lubing will be always better than stock switches anyway ;)
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline Bucake
« Reply #22 on: Sun, 31 January 2016, 18:25:48 »
didn't realize something like krytox was that.. sticky.
good to know, i guess :D
Offline jaffers
« Reply #23 on: Sun, 31 January 2016, 18:27:53 »
You can unlube krytox really quickly by making a solution of ammonia and bleach, it doesn't hurt the colour of the switches at all. Just chuck them in there without disassembly, then let them dry in the sun
« Last Edit: Sun, 31 January 2016, 18:32:50 by jaffers »
Offline platypus
  • dongerino adventures
« Reply #24 on: Sun, 31 January 2016, 18:32:54 »
You can unlube krytox really quickly by making a solution of ammonia and bleach, it doesn't hurt the colour of the switches at all. Just chuck them in there without dis assembly, then let them dry in the sun
