Author Topic: reducing alps tactility?  (Read 2554 times)
Offline roadblock2thesun
« on: Fri, 27 November 2009, 23:54:26 »
Hey everyone,
I have fallen in love with alps switches for a number of reasons, primarily the ease with which I can modify them.
I have come to an impasse however, I would like a switch that is a little "lighter." I have tried reducing the spring pressure by cutting down the spring, but this does not seem to achieve my goal.
I tried using the "non-click" leaves from a dell at101, but this is not what I want either. I want the switch to remain clicky, but just a little less resistance before the click.
I'm not sure If I have been clear or not...
Just wanted to see if anyone had any suggestions.
Looking forward to your replies,
Offline chimera15
« Reply #1 on: Sat, 28 November 2009, 01:10:57 »
Quote from: roadblock2thesun;136846
Hey everyone,
Well you want real complicated first, they have the lightest touch. I would say that the real cream dampened are probably the lightest.  If you have real complicated already, and it's still heavy, I'd say like Ripster said, maybe lubricate them, but I haven't had much success with that method.
I'd say get a Monterey keyboard.  They're clicky, but significantly lighter.
One strange thing I've noticed with my steampunk hack, which uses fake whites, is that it's significantly lighter than it was.  Probably due to the added weight of the old typewriter keys sitting on top of the switch.  Maybe something like that would help, pre-weighting the switch, maybe with something under the key cap like modeling clay or something.
Low profiles in the m1242 are really nice too.  But of course not as modifiable.
« Last Edit: Sat, 28 November 2009, 01:32:19 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
« Reply #2 on: Sat, 28 November 2009, 02:42:05 »
@Chimera15
The cream dampned ALPS contain a click-leaf that is nearly identical to the one found in the dell at101w, unless I'm missing something.
I have never heard of Monterey but will have to look into the, thanks for the suggestion.
I'm also intrested in the low profile switch you mention...
In the mean time, I'll continue watching your mod threads, you've got some good stuff.
thanks for the tips
Offline chimera15
« Reply #3 on: Sat, 28 November 2009, 02:55:53 »
Quote from: roadblock2thesun;136857
@Chimera15
thanks for the tips
Yes, you're right the leaf spring is the same.  The feel is different imo though.  Maybe I just got some very used blacks or something.  Perhaps it's that I don't bottom out as hard with the creams so it feels lighter to me as a result of that.
Edit:  You know what the difference is.  I figured it out.  The main barrel spring is slightly shorter on the creams I believe.  Going to verify that.
Cancel that, I popped open two new ones.  There doesn't appear to be any difference in length.  One appears to me, although it may just be because of bad lighting to be slightly more silverish, and the other slightly more yellow though.
I definitely had a larger spring in one of the keys I popped though.  Not sure if it was from one I tried to modify or what.....
Looking at them for like the 5th time now I think there might be a subtle difference in the springs.  A very small difference in how many times on the end they were wound a little different length.  It might just be from wear and use though.  I've mixed up which spring came from which switch at this point though and don't want to pop any others. lol
You already tried modifying the spring though to no effect? What happens when you do that?
The clicky leaf is half the height of the creams/blacks, they should be a little less resistant... but you already tried them and want even less hmm..  maybe if you press the clicky leaf in a book for along time or something it'll lessen it's resistance. lol
Try my weighting idea though, that might work well. ;)
Didn't one of Sandy's pages compare the different springs?
« Last Edit: Sat, 28 November 2009, 03:25:34 by chimera15 »
Alps boards:
Offline ch_123
« Reply #4 on: Sat, 28 November 2009, 05:17:52 »
The Blue Alps are also meant to be lighter, and if I recall correctly, a different spring. I intend on getting a Blue Alps board soon so I can comment then.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #5 on: Sat, 28 November 2009, 07:29:44 »
How much force is required to actuate a blue ALPS switch?
Offline chimera15
« Reply #6 on: Sat, 28 November 2009, 13:53:22 »
I should try that coin trick, but it's my general impression right now that blue alps are a tiny bit stiffer than my white real complicated alps.  I originally thought they were lighter, but I've changed that opinion.  But again it's tough to tell from my one case of them, and lots of other stuff can effect the overall feel of a board.
  It's possible that when I took my switches out of the pcb, and mounted them without a pcb the impression of them changed because they're no longer mounted in a pcb....
« Last Edit: Sat, 28 November 2009, 13:56:53 by chimera15 »
Alps boards:
« Reply #7 on: Sat, 28 November 2009, 15:48:36 »
It doesn't really matter if they feel just about the same. That could be why people use blue ALPS when repairing Northgates.
