Author Topic: NPKC 17 Switch Tester - mod to WORKING numpad!?  (Read 3248 times)
Offline Phenix
« on: Tue, 02 February 2016, 10:45:11 »
https://www.massdrop.com/buy/npkc-switch-tester
Hello
How would I make/transform this switch tester to an working numpad? I assume getting the pcb as an extra in the drop is recommend for that purpose..
Winter is coming.
Offline FLFisherman
  • I'd rather be fishing.
Re: NPKC 17 Switch Tester - mod to WORKING numpad!?
« Reply #1 on: Tue, 02 February 2016, 10:46:57 »
Not recommended; required. Additionally, I don't think that the PCB will output true number codes, but perhaps someone with the switch tester and PCB can tell me for sure.
Offline merlin64
    • MechMerlin
« Reply #2 on: Tue, 02 February 2016, 11:00:52 »
If you scroll through all the replies on massdrop you'll find someone who actually made their own pcb that lets you program the keypad however way you want. I'd go that route over the pcb massdrop offers.
Offline Phenix
« Reply #3 on: Tue, 02 February 2016, 11:59:19 »
your right. he says he designed something but didn't know if its working...
So basically solder switches onto pcb and add a cable = test if its working :eek:
Winter is coming.
