Author Topic: Esc key not working properly on Leopold FC660C?  (Read 5083 times)
Offline Lunatique
  • Writer, Composer, Artist, Photographer, Gamer
« on: Tue, 02 February 2016, 14:28:05 »
I usually use the FC660C with my smartphone, so I never had much use for the Esc key, but now I'm using it more with my PC, I've noticed that it doesn't really work, and I'd to find out why from fellow FC660C owners.
When I press the Esc key normally, it doesn't perform like a normal Esc would--nothing happens. For example, if I press Ctrl+****+Esc to activate the Task Manager, it doesn't work. If I'm in full-screen mode of a web browser (F11), pressing Esc does not get out of full-screen mode as it should normally. However, when I use the Esc key with Shift or Fn modifiers, I do get the ~ and ` (as according to the dip-switch setting).
So what's going on?
« Last Edit: Tue, 02 February 2016, 15:22:00 by Lunatique »
Offline appleonama
  • Trollo en USA
Re: Esc key not working properly on Leopold FC660?
« Reply #1 on: Tue, 02 February 2016, 14:53:54 »
fc660m or fc660c
Offline dgneo
  • Supervillain
« Reply #2 on: Tue, 02 February 2016, 14:57:32 »
I usually use the FC660 with my smartphone, so I never had much use for the Esc key, but now I'm using it more with my PC, I've noticed that it doesn't really work, and I'd to find out why from fellow FC660 owners.
So what's going on?
Func + Q will toggle the default action for the Esc key. Maybe try that combo, then try it out?
Offline Lunatique
« Reply #3 on: Tue, 02 February 2016, 15:23:39 »
fc660m or fc660c
Sorry, I forgot to specify. It's the FC660C, the Topre version.
Just tried it, and it didn't do anything except light up the Insert key LED.
