Author Topic: Best micro controller not using usb micro?  (Read 4570 times)
Offline ResonantPixel
« on: Wed, 03 February 2016, 08:08:37 »
Does anyone know the best micro-controller (for a keyboard), that does not use micro-usb type b, (mini-usb is best(I assume the) I thought maybe a teensy or ATmega328 Arduino Pro Mini I cant find anything on the port they use, I think most ardiunos use mini though : L, also I need two so if I can get the cheap copies of amazon uk that be great :P thanks!
« Last Edit: Thu, 04 February 2016, 12:42:46 by suicidal_orange »
Offline MAR82
  • Keyboard Addict
Re: Best micro controller not using usb micro?
« Reply #1 on: Wed, 03 February 2016, 08:17:59 »
The most common micro controller used for keyboards is the atmega32u4, that can be found on the Teensy 2.0.
There are cheeper versions out there, but as far as I know they all use micro USB connectors and not mini USB
Offline jd29
« Reply #2 on: Wed, 03 February 2016, 08:31:21 »
The Adafruit Trinket has a mini USB port. Edit: The Arduino Nano has Mini USB and plenty of pins. It doesn't have USB hardware, but you can emulate USB 1.1 (fast enough for a keyboard) using V-USB. As far as I know this will not be compatible with all the keyboard libraries out there, but this should help you.
« Last Edit: Wed, 03 February 2016, 08:44:29 by jd29 »
Offline user 18
Re: B
« Reply #3 on: Wed, 03 February 2016, 08:42:54 »
Why do you need the mini-USB so badly?
You could always use something like this and cut up a cheap micro USB cable to effectively give you a mini USB connection to a micro USB board.
E: There's probably plenty of premade adaptors out on ebay in the same price range, too.
Avatar by ashdenej
Offline Yoe
  • Alps & ISO <3
Re: B
« Reply #4 on: Thu, 04 February 2016, 02:04:20 »
I agree. Having a separate board or adapter for the usb jack to the harsh outside world is very much recommended. Easy to replace if damaged, and it keeps your controller intact. I sometimes use small adapters of the kind that has no wire inbetween connectors but both connectors in the same housing. I just cut away unwanted plastic to make it sit well in my build. I have also made my own jack plates from etched pcb and female mini usb vertical mount pcb connectors.
126949-0 126951-1 126953-2
Offline yangdigi
Re: B
« Reply #5 on: Thu, 04 February 2016, 03:31:30 »
For 60% or less Keyboard, Arduino Pro Micro is a good choice as it is very cheap with atmega32u4 controller.
And by using Pro Micro with 74hc138 or 74hc238,  Keyboard that has more keys can also be done.
Offline thatllbeme
Re: B
« Reply #6 on: Thu, 04 February 2016, 07:12:48 »
If you want a mini-USB port you should get a Teensy++ or clone (look for the 'at90usb1287' processor), but they're more expensive (£20/ea on Ebay) and harder to find cheap clones of. Micro->mini USB converter might be a better idea cost-wise.
Offline Yoe
  • Alps & ISO <3
Re: B
« Reply #7 on: Thu, 04 February 2016, 09:08:56 »
The regular Teensy 2.0 also has mini-USB. Cost much less than the Teensy++ 2.0.
Re: B
« Reply #8 on: Thu, 04 February 2016, 09:37:57 »
Thanks all, sorry this was a little of a poor-post I was rather knackered when writing it, and I screwed my point a little sorry :P
« Reply #9 on: Thu, 04 February 2016, 12:47:45 »
Title fixed, and to answer the question -
Teensy 2.0 is mini
Teensy 2.0++ is mini
Arduino Micro (official) is micro
"Arduino" Pro Micro (cheap clone) is usually micro, but there may be a version with mini if you look hard enough.
Offline iLLucionist
  • Topre is Love.
« Reply #10 on: Thu, 04 February 2016, 17:45:25 »
I want analog. What about mini jack as an kb interface?
