Author Topic: [IC] THE CLICK CLOCK  (Read 95652 times)
Offline Firebolt1914
  • POM Overlord
« on: Thu, 04 February 2016, 10:04:20 »
I have a rough idea of running a group buy of numitron clocks. I'm not sure if I should make an affordable acrylic case or a really nice aluminum case. I'm planning on having cherry mx switches as buttons although I have to see what sort of modifications I have to make.
I have access to a laser engraver so I can engrave some keyboard related things on the case. Here is an image of the original project done by Sean Voisen.
There most likely will be only 10-15 clocks done in a run.
Very rough estimate of 70 USD per clock. Higher price than I had hoped but not too bad
EDIT:
I am scratching the MX idea as the case is not too compatible with other switches. I don't think it's really possible unless you use wires to connect the switch to the PCB. Even if the case were to be modified, the parts are at the same level as the switches.
NEWEST EDIT 12/22/2016
NOW TO BE IN VFD FORM!
VFDs are different than the previously proposed Numitrons as they are not filaments, but instead are based on cathodoluminescene.
VS
Right now, once the maker of the PCB (www.nixieclock.org) responds to me, I will begin to make a case. I have still not decided between acrylic or aluminum. Aluminum will be more expensive, however I believe it will look the nicest with this type of vacuum tube. Please let me know so I can begin ASAP. I will post a rough approximation of what I want the aluminum case to look like soon.
Example of CNC'd aluminum IV-11 Clock
Possible Design(s):
« Last Edit: Thu, 29 December 2016, 19:50:05 by Firebolt1914 »
Offline 64rky
Re: [IC] THE CLACK CLOCK
« Reply #1 on: Thu, 04 February 2016, 10:06:14 »
Holy cow,  that looks cool!  I'd be down for one!
Edit: I like the acrylic case,  just looks cool!
Offline nmur
  • ಠ_ಠ
« Reply #2 on: Thu, 04 February 2016, 10:07:39 »
I've always wanted one of those!!
« Reply #3 on: Thu, 04 February 2016, 10:09:55 »
What is that?
Offline fliptrik
« Reply #4 on: Thu, 04 February 2016, 10:10:22 »
Very slick. What's the rough price point your aiming for?
Offline FLFisherman
  • I'd rather be fishing.
« Reply #5 on: Thu, 04 February 2016, 10:10:31 »
You said you wanted to use Cherry MX switches as buttons. How would that work? I don't see where the buttons would be.
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #6 on: Thu, 04 February 2016, 10:12:44 »
I'm always down for some nixies. Count me in
Offline Zapheo
  • There's nothing that I wouldn't do.
« Reply #7 on: Thu, 04 February 2016, 10:13:40 »
This looks like a headphone amplifier.
I need more keyboards to hold all of these keycaps.
Offline whmeltonjr
« Reply #8 on: Thu, 04 February 2016, 10:13:48 »
I could be interested depending on cost.
Offline qazeqaz
« Reply #9 on: Thu, 04 February 2016, 10:14:30 »
I would be in for one of these bad boys!
« Reply #10 on: Thu, 04 February 2016, 10:14:44 »
Nixie clock?? Sign me up!!  :D
@FLFisherman, the AM/PM and Alarm buttons on each side of the tubes.  :)
Offline FLFisherman
« Reply #11 on: Thu, 04 February 2016, 10:15:54 »
Ah, I see. In that case color me interested!  :thumb:
  • POM Overlord
« Reply #12 on: Thu, 04 February 2016, 10:25:07 »
The important part of this possible clock is the fact that it uses numitron tubes instead of actual nixies. Niches require around 180VDC which put me off. Numitrons require about 5V, which is much safer and requires less circuitry.
I may want a poll for either acrylic or aluminum case.
Also, what sort of thing would you want laser engraved?
Offline 64rky
« Reply #13 on: Thu, 04 February 2016, 10:30:17 »
The number of the unit,  possibly the username :)
Offline Hexterdude
  • I have a problem when it come to artisans
« Reply #14 on: Thu, 04 February 2016, 10:35:15 »
I'd love to get one of these
  • Live long and prosper
« Reply #15 on: Thu, 04 February 2016, 10:36:16 »
does it support 24-hour time format?
tp thread is tp thread
« Reply #16 on: Thu, 04 February 2016, 10:40:30 »
I know, I just like nixies (and not just because my cat is named nixie). Something about their warm glow can't be encapsulated by numis. But I understand the reasoning. IIRC the tubes are similarly priced, but the lower voltage should make the kit as a whole much cheaper. I would guess $75-100 depending on the case?
Offline mobbo
  • u fk
« Reply #17 on: Thu, 04 February 2016, 10:48:39 »
This looks super cool.
Personally I'd just like my GH username engraved. Or even the the Geekhack logo itself (not sure about permissions around this).
If you did aluminium cases I imagine you could get some pretty detailed images or designs on there.
Quote from: Binge
Offline jerue
  • (Whenever that happens :P)
« Reply #18 on: Thu, 04 February 2016, 10:58:36 »
whoa.
interested depending on price.
Offline LukStarkiller
« Reply #19 on: Thu, 04 February 2016, 12:11:23 »
I prefer nixies but interested anyways
Offline livingspeedbump
    • KeyChatter
« Reply #20 on: Thu, 04 February 2016, 12:13:10 »
Im so ***** in for this  :thumb:
<- My Collection (so far)
    • KeyChatter
« Reply #21 on: Thu, 04 February 2016, 12:14:40 »
Yeah, I like this idea. Simple and elegant. Or GH logo / username
Offline chilldude_22
  • Official streetman
« Reply #22 on: Thu, 04 February 2016, 12:31:52 »
Always wanted an aluminum Nixie clock. Consider me interested!
    • KeyChatter
« Reply #23 on: Thu, 04 February 2016, 12:33:11 »
Tube clock, technically not a Nixie ;)
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #24 on: Thu, 04 February 2016, 12:34:05 »
Interested if aluminum.
« Reply #25 on: Thu, 04 February 2016, 12:34:19 »
I still don't know what I'm looking at...
« Reply #26 on: Thu, 04 February 2016, 12:41:05 »
WHATEVER
Offline trizkut
« Reply #27 on: Thu, 04 February 2016, 12:43:20 »
Interested
Offline Dongulator
« Reply #28 on: Thu, 04 February 2016, 12:47:32 »
Interested for sure.
Offline RoastPotatoes
    • RoastPotatoes Keyboard Blog
« Reply #29 on: Thu, 04 February 2016, 12:53:25 »
Interested. These are awesome.
Offline Psybin
  • of Rallos Zek
« Reply #30 on: Thu, 04 February 2016, 13:02:49 »
Interested also.
    • KeyChatter
« Reply #31 on: Thu, 04 February 2016, 13:12:14 »
Kits on ebay for something very similar to this are around $120ish, so I'd expect something similar, if not slightly more for this.
Offline Dee1
« Reply #32 on: Thu, 04 February 2016, 14:39:24 »
Interested in this. :)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #33 on: Thu, 04 February 2016, 15:27:05 »
I was looking at getting a kit for a nixie tube clock but I wanted the bigger tubes and a proper 5 instead of the upside down 2.  Was expensive.  I might swing this depending on final price.
« Reply #34 on: Thu, 04 February 2016, 15:27:58 »
OH... HA HA!
THERE ARE NUMBERS ON THE TUBES!!!
Offline Dernubenfrieken
« Reply #35 on: Thu, 04 February 2016, 15:39:42 »
It should be the "click clock"
Ill show myself out
  • POM Overlord
« Reply #36 on: Thu, 04 February 2016, 15:51:31 »
Ill show myself out
I love it
« Reply #37 on: Thu, 04 February 2016, 17:42:46 »
My bad, I didn't realize numitron was a different thing.  :thumb:  Thanks for clarification.
Engraving should be #, (optional) geekhack, and (optional) username, in no particular order.  At least that's my vote.  It also depends on the intent here, whether you want to make a geekhack clock or just a clock that is sold on geekhack.  :)
Re: [IC] THE CLICK CLOCK
« Reply #38 on: Thu, 04 February 2016, 17:59:36 »
What is that?
a time teller
i'd get one, if it had the hhkb logo engraved on the bottom right hand corner just like the hhkb OuO
  • POM Overlord
« Reply #39 on: Thu, 04 February 2016, 18:07:39 »
My intent was to get a bunch of clocks that are interesting and have some sort of geekhack flair. There will be a custom case, and hopefully it won't be too expensive. If it is too expensive, I will switch to the acrylic case.
« Reply #40 on: Thu, 04 February 2016, 18:13:47 »
:thumb:
Building off what demik just said, it might be fun to let people put etchings of their favorite keyboards on it in the style of the pixel art photos in peoples' sigs?
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #41 on: Thu, 04 February 2016, 18:49:17 »
Definitely interested! Most likely interested in the acrylic case. I love how it looks.
« Reply #42 on: Thu, 04 February 2016, 19:16:16 »
Can you make one that tells me when the next clack sale is?
Offline Spaceman1200
« Reply #43 on: Thu, 04 February 2016, 19:58:47 »
Interested depending on the price
Offline turboloser
« Reply #44 on: Thu, 04 February 2016, 20:00:16 »
I would be pretty interested, I considered getting a Nixie years ago but sort of just forgot.
Offline Sinanju
  • Dustoff
« Reply #45 on: Thu, 04 February 2016, 20:03:03 »
Human, not miracle worker.
Would be interested depending on price. Looks great w/ acrylic.
« Reply #46 on: Thu, 04 February 2016, 20:08:55 »
I'm very interested in this
Offline GL1TCH3D
« Reply #47 on: Thu, 04 February 2016, 20:09:27 »
Curious...
Offline Hellcatz
« Reply #48 on: Thu, 04 February 2016, 20:20:50 »
depends on the price
Offline Siegx
« Reply #49 on: Thu, 04 February 2016, 21:08:11 »
Definitely interested if the price is good.
