Author Topic: Cherry Brown switch stopped bumping after one week of usage. Durandal G1NL  (Read 2075 times)
Offline fatum
Hi guys,
I bought a Durandal G1NL with brown switches one week ago, and just now found that "g" key does not have bump at all - absolutely linear to the bottom. I am 90% sure it was Ok when I bought it.
Can I fix it or it is something i have to live with? I do not do soldering.
Also i am a bit dissapointed as all they keys are not "smooth".
My razer blackwidow with blues felt better.
Thanks.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Cherry Brown switch stopped bumping after one week of usage. Durandal G1NL
« Reply #1 on: Fri, 05 February 2016, 02:25:52 »
Cherry switches are not smooth.
It's been reported that it takes a while to break them in. The value quoted for this ranged from several weeks to 15 years xD .
MX Brown is also one of the more polarising switches in the lineup.
Offline fatum
« Reply #2 on: Fri, 05 February 2016, 02:58:11 »
Hi. Thanks.
What about the switch which stopped bumping and become linear? Can it be fixed?
« Reply #3 on: Fri, 05 February 2016, 03:02:33 »
I don't think it's possible to wear away the bump in a week, the only way a brown could be linear is if it was defective from the factory.  Can you exchange it under warranty?  If not you need to find a friend with a soldering iron...
Offline fatum
« Reply #4 on: Fri, 05 February 2016, 09:08:09 »
I was thinking about replacing it through Amazon, but then I found that it would cost me 30+ euro for delivery while Amazon compensates only 8 euro. And replacement delivery process is not transparent - too many different labels.
I decided to leave it as it is. Amazon provided me with 10 euro gift card for the next purchase.
In the end, some people buy a full keyboard of red switches and I have only one  ;D. Just disappointing that new keyboard can have such issue.
« Reply #5 on: Fri, 05 February 2016, 10:30:58 »
I keep reading Chris Brown
Offline Geroximo
« Reply #6 on: Fri, 05 February 2016, 18:00:28 »
A lot of people think, that MX Browns feel like scratchy MX Reds.
Myself included. It's not a bump, it's a scratch. I ordered a MX brown board and had to send it back the next day, because MX Browns are just garbage.  :-X
You think the color of MX Browns was coincidence? I say:It was not! Just think about what else has the color brown .... yeah, right.
Anyways, if you cannot return it, the only way to fix it is soldering.
Offline falkentyne
« Reply #7 on: Fri, 05 February 2016, 18:32:58 »
God you're so depressing and this is grossly unfair.
Out of four mx boards, only one felt it had  scratches instead of bumps, on about three keys, and that was a really inconsistent ducky shine 3 (right during that time when there was a shortage of any good quality browns because Logitech had bought them all out).  I'm guessing the stem itself was bad or worn out, as the bump is caused by a bump on the lower part of the black shaft.
The second Shine 3=decent.
The Logitech G710+ = perfect.
The Shine 4 and Year of the Goat browns= great.
The bumps are on every key and you can feel them if you press slowly.
Offline Shaussman
« Reply #8 on: Fri, 05 February 2016, 18:48:39 »
Yeah, Browns don't feel quite like scratchy browns; the bump is substantial enough to be noticeable while typing. That's not really the issue at hand, though
MX Brown Quickfire XT | MX Clear WASD VP3 | MX Blue Ducky Zero
Offline Mattr567
« Reply #9 on: Sat, 06 February 2016, 00:40:18 »
15 years sounds right. MX Browns from my old G80 11800 (now modded to clears) are much smoother than new MX Brown.
IBM P77, SKCC Green, 1984
