Author Topic: Help, Pok3r LEDs, problem>  (Read 2145 times)
Offline Azzie
« on: Fri, 05 February 2016, 07:22:57 »
Hi Everybody.
I soldered leds on mine pok3er but two rows are not working, u can see what i am talking about in pictures.
Any1 has any idea what is wrong. Please help
Thank you
Offline Moistgun
  • Slippery When Wet
Re: Help, Pok3r LEDs, problem>
« Reply #1 on: Thu, 11 February 2016, 09:18:37 »
Are you certain you installed the LEDs with the correct polarity?
You might have literally installed a group of them the wrong way.
However, It is very strange they are in the two rows like that.
« Last Edit: Thu, 11 February 2016, 09:21:32 by Moistgun »
Offline Azzie
« Reply #2 on: Thu, 11 February 2016, 15:47:11 »
They are all instaled same way. ill post pictures of that tomorow.
When i done top row of numbers i checked, are all LEDs working and 4 and 9 didnt work. I just went forward hoping other LEDs will work, and that picture is result...its interesting patern of LEDs not working.
It bothers me so much...ill need to get a nice set of keys and not use backlight....
Cos i have no idea how to fix that, and like this, atleast keyboard works nice, it has reds and i use it for gaming mainly!!
Sorry for bad english, if anyone has some idea what could be wrong pls write...
Thank you
Offline yobinad
« Reply #3 on: Thu, 11 February 2016, 17:23:54 »
Maybe a pcb problem?
You should check it with a continuity tester
