Author Topic: Does anybody here know much about ARON keyboard?  (Read 4911 times)
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« on: Mon, 30 November 2009, 19:00:54 »
I surfed around on some Korean websites and learned that a Korean company named ARON making very good mech. switch keyboard.
http://www.fzsky.com/aron/us/pro.asp
Some of their model:
KB-A106S
http://iomania.co.kr/frontstore/Item/item_zoom.asp?item_num=5&catalog_num=&mart_id=iomall&level=&mother_catalog_num=103895
KB-A109 <--- very good one, ergonomic style
http://www.diytrade.com/china/2/products/3290484/诚招游戏键盘_机械键盘_西南区域代理加盟.html
http://fv521.egloos.com/2791639
I would love to get insight more on this brand
http://review.search.nate.com/review.html?search_select2=on&t=0&q=ARON
A Google translated text from a chinese store about ARON:
(A). ZOOM 109 Pro + (U) Black Urethane
High-quality black polyurethane lamination process is used Zoom109Pro keyboard look matte black polyurethane lamination technology to put their hands up when compared with the plastic feel very comfortable keyboard, and a warm feeling. This high-brightness LED keypad with three high-brightness light, rapidly clear you are prompted to convert button.
And the market a number of different membrane keyboard, ZOOM KB-A109 with built-in smart chip, one-touch life of 20 million times more input speed faster than conventional membrane-type keyboard, 1 / 2 to 2 / 3. The price off than those in the same category of other mechanical keyboard, much cheaper. Aron mechanical keyboard is the first in China, the market price generally lower than the same type of foreign mechanical keyboard, discount 35%. The new goods such as CHERRY should be 700-1000 dollars.
The use of a true ergonomic keyboard designed to hold two original principles of the invention patents (three-dimensional keys and Atype.Vtype), the whole appearance is a gentle curve shape, the character according to the middle as the base is divided into right and left sides, was "Eight "type arrangement, perfectly suited to the natural hands-off position when typing, wrists, fingers, shoulder and elbow feel very comfortable with ease. Each used a true ergonomic keyboard, people will thoroughly tired of ordinary keyboard, because they will find themselves can no longer tolerate the use of other keyboard. This is the greatest charm of ergonomic keyboards. If you want to spend a most comfortable keyboard Heart, we strongly recommend that you select this value was hard to imagine new products.
The ergonomic design of the natural principle of full use of ergonomic design, the entire shape is a gentle curve shape, character keys to the middle as the base is divided into right and left sides, was "eight"-shaped arrangement, perfectly suited to the natural hands-off position when typing, wrists, fingers, shoulder, and elbow are very comfortable, easy; because of people's fingers may be long or short, so the design of key high and low, allowing you to naturally and accurately hit keys at any time without bending the fingers; the arrow keys was "10" character arrangement, makes it easy to identify the direction; pallets part of the arc-shaped design, naturally smooth, comfortable let go up, while accurate card bit, sliding the right hand to the right, accurate touch-keys and numeric keys. But also has a key to open, close, and the size of the window function. Has a unique interface PS / 2 and USB interfaces. Trademarks unique three-dimensional trademarks, highlighting high quality.
(B). ZOOM KB-A106 (mechanical keyboard)
A: mass -
High-quality black polyurethane lamination process is used Zoom109Pro keyboard look matte black polyurethane lamination technology, feel very comfortable and a warm feeling. Black exterior, rustic elegance. This high-brightness LED keypad with three high-brightness light, rapidly clear you are prompted to convert button.
UV Silk Coating Key Top ordinary printing characters easily sweat, water, alcohol and other liquid caused by falling, so this character on the keyboard in the chemical resin coating to prevent the character off, durable. Other properties using the PS / 2 interface. U-shaped Body Line keys with the keyboard height adjusted to a comfortable U-shaped bend.
A106 single-button input can reach 20 million times or more; the general membrane-type keyboard would Commitment 3 to 6 months of the warranty, while the mechanical keyboard usually has two years to five-year warranty, but now ARON's ZOOM KB-A106 could provide 3-year warranty and lifetime maintenance.
B. Game Model
ZOOM KB-A106S Game Keyboard
Features: The two kinds of ivory color, hue and elegant; three green lights, lighting soft. Semi-permanent laser-printed Key Top, easy to wear and tear. Long life, more than 20 million times or more. Even if any components can be repaired due to accidental damage, reaching well preserved. Using the PS / 2 interface.
Infinity input from key places of conflict, infinite input, designed for gamers to create, in the present today a wide variety of competitive games, a good mouse and a good keyboard can reflect the operation and advance the awareness is equally important The. Infinity input, is really very high-handed!
Infinity input can be done to maximize the non-key bit of conflict, usb can support up to 8 keys simultaneously input, while the PS2 is no limit, so once, and others challenge war3, CS, Audition, kof, this Infinity input almost said the Invincible!
(3): ZOOM-107S mechanical keyboard
A: mass -
This keyboard is specifically for ARON's consumers demand high-quality design. A standard 106 key design, green shaft fretting, built-in smart chip, one-touch life of at least 20 million times or more, an independent CHERRY mechanical switch is more durable. Input speed is faster than conventional membrane-type keyboard, 1 / 2 to 2 / 3.
With the market quite a mixed bag compared to thin-film-style keypad that this section keyboard biggest advantage is: durable, typing speed and error hit rate is low. Much cheaper off than the price of similar products. The 107 is currently the most popular in foreign countries, and is characterized by simplicity and good taste is the office typing on the on the choice.
If you are required for the office, or skilled in collections, we recommend you choose this economical type KB-107
B: C8X mechanical keyboard
The mechanical keyboard is a typical blue-axis multi-function keyboard. CHERRY use a separate mechanical switch, built-in smart chip, one-touch life of 20 million times more than input speed generally faster than conventional membrane-type keyboard, 1 / 2 to 2 / 3.
This keyboard, unique, exquisite workmanship, has other unique advantages of a regular keyboard, making it unique in a number of keyboard. First, it feels light, machine-style buttons in the spring focused on the specific issue of typing click the crisp sound.
Second Life lasting, ultra-high-touch usage, at least up to 20 million times over and have three years warranty, lifetime maintenance (maintenance of course, money's)
The biggest advantage of the keyboard is that it can be a multi-purpose button. Transformed through special keys, using a keyboard to control two computers. Both easy to use saves resources, is a computer professional of choice.
« Last Edit: Mon, 30 November 2009, 19:23:24 by joneslee85 »
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline PRISONER 24601
« Reply #1 on: Mon, 30 November 2009, 19:34:48 »
I saw this Korean movie about how in the future, people get high off of poop, so these drug dealers try and make everyone poop a lot and then they steal the poop and make drugs from it.
profit.
oh, keyboards... that zoom 109 looks really cool and comfortable (for an ergonomic). I'd like to get one of those. Maybe two.
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
