Author Topic: [IC] SA Dasher and SA Dancer sculptured keysets (GB completed)  (Read 159771 times)
Offline zslane
Re: [IC] SA Dasher and SA Dancer sculptured keysets
« Reply #250 on: Mon, 14 November 2016, 18:13:42 »
I will also be tweaking the SPECIALTY kit ever so slightly to better support WhiteFox, TADA68, Red Scarf 68, and similar boards which have a vertical row of 1u keys on the far right.
Offline clappingcactus
« Reply #251 on: Mon, 14 November 2016, 20:49:41 »
Wait is the drop confirmed for December? Last I heard it was a possibility...
Well, if you can, you can add support for VE.As with a single blank 2.75u row3 key (assuming the ergodox keys are 1.75u blanks)
Sent from my Pixel using Tapatalk
Offline hoq
    • wolfmark.work
« Reply #252 on: Mon, 14 November 2016, 20:52:07 »
DVORAK/COLEMAK and ERGODOX kits have been added to the December drop:
OMG、dream comes true!
Offline hoq
    • wolfmark.work
« Reply #253 on: Mon, 14 November 2016, 20:54:13 »
dc backspace is 1.75u in R3
« Reply #254 on: Mon, 14 November 2016, 20:55:47 »
Blanks are nicer than inconsistent legends.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #255 on: Tue, 15 November 2016, 00:01:22 »
He's saying that the Backspace key in Dvorak&Colemak kit should be 1.75u instead of 2u, which OP is aware of by now. Has nothing to do with the legend.
Offline My_Thoughts
« Reply #256 on: Wed, 16 November 2016, 06:52:11 »
As you are expanding the sets (Thanks for Colemak BTW) Would you consider adding the extra row to the numpad for us special people with an external numpad?
Always worth asking :)
Thanks
Offline Niomosy
« Reply #257 on: Wed, 16 November 2016, 13:26:44 »
I believe zslane mentioned receiving confirmation from MassDrop on a December launch for the sets.
Offline zslane
« Reply #258 on: Wed, 16 November 2016, 14:52:10 »
Indeed.
But it was reported back in Reply #224, on Oct 10, which a newcomer or casual lurker might not have seen.
Offline e_l_tang
« Reply #259 on: Wed, 16 November 2016, 15:57:28 »
Indeed.
Maybe you should edit the title or the OP. It might even help some people avoid missing the drop.
Offline zslane
Re: [IC] SA Dasher and SA Dancer sculptured keysets (expected DECEMBER drop)
« Reply #260 on: Wed, 16 November 2016, 16:35:55 »
Good suggestion. Done!
Offline Niomosy
« Reply #261 on: Wed, 16 November 2016, 19:57:24 »
Indeed.
True, it was reported a while back.  I hadn't meant anything negative or snarky in the comment, just meant as a factual answer was all.
Offline zslane
« Reply #262 on: Wed, 16 November 2016, 20:30:50 »
Sorry, that was me projecting.
Offline lithopedion
« Reply #263 on: Fri, 18 November 2016, 06:00:29 »
I know it may be to late to ask now, but is there any chance you add a planck/atomic kit?
I think the colors will be really cool on a planck.
Offline zslane
« Reply #264 on: Sat, 19 November 2016, 11:59:06 »
You're in luck! I'm working on Planck kit renders as we speak.
Offline lithopedion
« Reply #265 on: Sat, 19 November 2016, 19:01:38 »
Wow! Excellent news! :thumb:
Offline pschoen
« Reply #266 on: Sun, 20 November 2016, 00:20:05 »
will there be also support for nordic iso ?
Offline zslane
« Reply #267 on: Sun, 20 November 2016, 10:09:44 »
If I have enough free time before the December drop, I will try to put together a Nordic/DE kit.
Offline zslane
« Reply #268 on: Sun, 20 November 2016, 17:24:34 »
Here's a peek at what a Planck might look like with Dasher on board:
153323-0
Offline Hypocaffeinic
« Reply #269 on: Mon, 21 November 2016, 02:53:10 »
Oh my!  :-*
Offline zslane
« Reply #270 on: Tue, 22 November 2016, 20:45:47 »
Tentative drop date is currently 12/12/16. Be sure to set aside some of that Christmas shopping money!
Offline hoq
    • wolfmark.work
« Reply #271 on: Tue, 22 November 2016, 20:59:21 »
“double 12”, a good shopping day.  :))
Offline PatchSalts
« Reply #272 on: Tue, 22 November 2016, 21:10:39 »
Tentative drop date is currently 12/12/16. Set aside some of that Christmas shopping money!
IT'S HAPPENING. Will it last a week? I don't know much about drop durations.
« Reply #273 on: Wed, 23 November 2016, 01:28:50 »
Usually a couple weeks.  :thumb:
Offline ticktwo
  • -kbdfan
« Reply #274 on: Wed, 23 November 2016, 02:11:02 »
I will take note of this keyset in my wishlist! I'm interested :p
HHKB | Leopold FC750R | Mech27 (soon) | TX-75 (soon)
Offline Niomosy
« Reply #275 on: Thu, 24 November 2016, 00:03:27 »
Drops are typically two week runs that I've seen.
Offline zslane
« Reply #276 on: Fri, 25 November 2016, 17:06:14 »
Why do SA Nordic kits supply a row 2 "Z" key when the existing row 4 "Z" key in every base set can be used for this?
Offline Oblotzky
« Reply #277 on: Fri, 25 November 2016, 17:52:15 »
From what I know it's because its not perfectly symmetrical. I'm looking at various pictures right now though and it seems to be, but I very much remember seeing a post where someone pointed out that his Z was flipped on a R3 board and it was indeed visible, but maybe I remember incorrectly and it was the X or so. I'll have my Nantucked soon and will see for myself if I will be dropping it from my set or not.
Offline zslane
« Reply #278 on: Fri, 25 November 2016, 22:02:37 »
That was my theory too, except then I tested that theory with PuLsE. I took the Z keycap, rotated it 180 degrees and put it in place of the Y, and it looked perfect.
Offline zslane
« Reply #279 on: Tue, 29 November 2016, 15:13:48 »
NORDE kit has been submitted to MassDrop.
Offline My_Thoughts
« Reply #280 on: Wed, 30 November 2016, 06:36:20 »
Is there an offical answer from massdrop about what happens when child deals don't make their MOQ?  I purchased Royal Navy and one kit did not meet MOQ so there was an option to pay more for that child set to be made.  Does Massdrop do that as well?
Offline zenless
« Reply #281 on: Wed, 30 November 2016, 08:01:16 »
Tomorrow is December!
Oh god the waiting!
Offline need
« Reply #282 on: Wed, 30 November 2016, 08:24:11 »
What row are those 1u modifiers in? Do they have a profile or all row3 ?
Offline zslane
« Reply #283 on: Wed, 30 November 2016, 12:42:37 »
The PLANCK kit is sculptured:
154161-0
Offline anorak
« Reply #284 on: Wed, 30 November 2016, 13:34:47 »
Waaa! Many thanks for this! I really like the colors, but without norde kit, I won't by the base kit.
Offline need
« Reply #285 on: Wed, 30 November 2016, 16:11:56 »
That's exactly what I wanted  :thumb:
Offline Parva Ovis
« Reply #286 on: Thu, 01 December 2016, 00:10:02 »
Do you have price quotes for the newer kits?
Offline Oblotzky
« Reply #287 on: Thu, 01 December 2016, 02:29:33 »
Just installed Nantucket on my board and closely inspected the Z key, it's definitely symmetrical and I'll be dropping it from my International kit.
Offline hoq
    • wolfmark.work
« Reply #288 on: Thu, 01 December 2016, 04:31:40 »
yes, I checked my PuLSE and CARBON, Z key can be used not only in R4 but also in R2 when it been reversed
Offline hoq
    • wolfmark.work
« Reply #289 on: Thu, 01 December 2016, 05:16:24 »
So. finally, will we see some novelties keys for Dasher and Dancer?
If you don't privide any novelties, I really hope to design a set for it!   ;)
Offline Oblotzky
« Reply #290 on: Thu, 01 December 2016, 05:56:18 »
Personally I don't see why this set would need novelty icons, it's kept very classic with almost text only. Then again I haven't seen what someone might come up with.
Offline hoq
    • wolfmark.work
« Reply #291 on: Thu, 01 December 2016, 06:31:33 »
Yes , I really understood the original purpose of this set.
I don't attempt to change zslane's mind, the kits and the color matching is good enough.
Offline zslane
« Reply #292 on: Thu, 01 December 2016, 12:33:30 »
I have old quotes from late last year, but nothing for the latest kits. Besides, kit pricing is something MassDrop, not I, negotiates with SP. They are awaiting that information as we speak.
Offline formfly
« Reply #293 on: Thu, 01 December 2016, 13:08:57 »
kinda love it and interested with these keycaps set
hope my wallet going full before the drops  :p
« Last Edit: Thu, 01 December 2016, 13:26:58 by formfly »
Offline Niomosy
« Reply #294 on: Thu, 01 December 2016, 17:13:56 »
Looks like this drop will be slotted at some point after GMK Retro finishes?  That one's got 5 more days left.
Offline zslane
« Reply #295 on: Thu, 01 December 2016, 18:03:46 »
And fewer than 60 preorders. Which supports my belief that SA Retro was more than just a colorway.
Offline Niomosy
« Reply #296 on: Thu, 01 December 2016, 18:14:06 »
Oh wow, I hadn't even looked at the purchase count.  I was not expecting that low a count, honestly.  Lots of calls for SA in the comments, I see.  I'm wondering if they're going to try extending it or just let it relaunch at some future point.
Offline elfick
  • Can I get Colemak and a side of fries with that?
« Reply #297 on: Thu, 01 December 2016, 21:59:50 »
With 1965 and XDA in GB, Dasher imminent, GMK Honeywell likely, and GMK >Terminal_, GMK Nautilus, and Classic Space showing such strong ICs, there's a lot of competition. And those are just the GBs I'm interested in... I'm sure there are others.
Offline zslane
« Reply #298 on: Thu, 01 December 2016, 22:35:13 »
Honeywell is another one where the colors are only half the story. Without high-profile spherical keycaps, it doesn't really deserve to be called Honeywell, IMO.
Offline formfly
« Reply #299 on: Fri, 02 December 2016, 07:05:07 »
in my opinion, the fight is only between SA Dasher and Nautilus
but you have my vote Dasher!  :-*
I love you at first sight hahaha
