Author Topic: EMI Shielding on Model F?  (Read 71414 times)
Offline msiegel
« on: Tue, 01 December 2009, 14:36:42 »
I'm curious why the entire inside of the case is sprayed with black EMI shielding paint... was it just easier to manufacture that way?
The Model F switch assembly is a sandwich between two grounded steel plates, so *it* should already be well shielded, right?
By comparison, the Model M has no EMI shielding at all, if I'm remembering correctly.
Offline ak_nala
« Reply #1 on: Wed, 02 December 2009, 03:19:02 »
IIRC, back in the good ol' days, when personal computers were new and shiny (and mostly Apple, Atari and Commodore :-), the original FCC regs for home computer equipment mandated that there be no, nada, zilch emissions of any kind from the case. This resulted in some truly impressive over-engineering in computer cases and keyboards (which have there own processors inside, after all) with mega-shielding throughout.
These regs were relaxed after a few years (late mid-80s, IIRC) to where it simply had to not emit anything that might interfere with signals or other electronics and had to absorb anything it received without re-emitting it, which also helped in making things cheaper.
No matter where you go, there you are...
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #2 on: Wed, 02 December 2009, 03:35:13 »
Incidentally, PS/2 systems apparently had very low radiation levels, which made them popular with hams for packet radio and other such applications.
Offline msiegel
« Reply #3 on: Thu, 03 December 2009, 14:08:09 »
Quote from: ak_nala;137936
ahh, that makes sense :)
