Author Topic: Garlicaps: ({||})  (Read 46928297 times)
Re: Nightcaps: | | |
« Reply #8300 on: Sun, 04 June 2017, 02:04:10 »
Did you try anything different? A friend said to use a knife, but I don't want to risk damaging the cap  :-X
I've had this issue before
Don't force on the cap, if it's too tight you'll likely break the stem. I use a small file to slowly widen the cruciform on the bottom of the keycap, any local hardware store should have one that'll work. An exacto knife could work but I don't think you have as much control over the size as a small file gives you.
Offline moonmaster
  • big bumps, beautiful boards
« Reply #8301 on: Sun, 04 June 2017, 08:07:30 »
So I'm able to put my moondrop, but not the bombking on my keyboard. The stem is too tight, cause when I tried to push down, the stem just presses down into the switch.
Anyone have any suggestions I could try? Or is this something I need to let ETF know?
Thanks.
Mine was very tight and I got it to work eventually.  In retrospect maybe I shouldn't have taken the risk of breaking the stem..
No special tricks that I used.
Don't use a knife. Reach out to ETF first to see what he says.
Offline Arcsxum
« Reply #8302 on: Sun, 04 June 2017, 12:34:49 »
Thanks.
Thanks.
Thanks for the replies guys. I'll wait to hear from ETF first, before trying anything.
Offline braidn
« Reply #8303 on: Sun, 04 June 2017, 12:44:07 »
These are quite tight which is great because Gateron heads these days seem very thin. If you have a Gateron switch lying around (clear/black) give it a whirl there and then on a thicker headed switch.  I had this exact problem
Offline Namkhanhv
« Reply #8304 on: Wed, 07 June 2017, 03:03:02 »
Bomdrops came in today and they look phenomenal. Thank you, ETF   :thumb:
Potato GID pic
Offline shinz0
  • i was told there would be cake
« Reply #8305 on: Thu, 08 June 2017, 12:57:01 »
I didn't plan on getting this set. Everything just kind of fell into place. What a happy little accident.
NSFL, proceed at your own risk.
unfortunately, i received the eggface with a little crack in the stem. RIP....
My first cracked stem. hit me with some tips on how to save this guy.
Offline Tally810
« Reply #8306 on: Thu, 08 June 2017, 13:00:32 »
FYI shinzo my eggface also has a hairline Crack.  You can only see it if you look closely but I am scared of this happening.  Let me know what you do to shore it up as I'll do the same with mine.
Sent from my SM-G928V using Tapatalk
Offline dorf
  • divine creator
« Reply #8307 on: Thu, 08 June 2017, 13:01:22 »
Gold!
Offline ArchDill
« Reply #8308 on: Thu, 08 June 2017, 13:05:14 »
Seems like I have seen that a few of the new caps have REALLY tight stems. Tally, was it cracked when you received it or after put it on, Just curious.
I had received a Sparkey that scared the hell out of me to put on.
Offline Tally810
« Reply #8309 on: Thu, 08 June 2017, 13:06:51 »
It came this way but it is very very slight.  I just don't want it to blow up like the one in the picture above. :/
Offline shinz0
« Reply #8310 on: Thu, 08 June 2017, 13:14:43 »
i'm just going to leave mine unmounted for now. i'd hate for that part of the stem to break all the way off.
Offline moonmaster
« Reply #8311 on: Thu, 08 June 2017, 14:59:31 »
Yikes, mine was super tight. Now I am scared to take it off to look.
Offline cribbit
« Reply #8312 on: Thu, 08 June 2017, 20:46:58 »
Mine seemed far too tight visually and I couldn't get them on (didn't want to force them) but they seem to be fine now. I just had to be very gentle with them and line them up perfectly. Once they're properly centered they don't take any effort to put on.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Offline Meitachi
  • Je sui prest
« Reply #8313 on: Fri, 09 June 2017, 17:47:22 »
170450-0
A tad late but I'm in love with the Robin Egg Hue fugu.
Offline ejewell89
  • 4ever Smol
« Reply #8314 on: Fri, 09 June 2017, 17:49:23 »
Better late than never bby. :) iz good kep
Offline frostylove
« Reply #8315 on: Fri, 09 June 2017, 19:20:12 »
What is your keyboard?
Suhr Custom Standard Carve Top
Manson DL-1 Matt Bellamy Signature
Marshall JVM410H + 1960A
Lovepedal Kanji Enternity
Offline Meitachi
  • Je sui prest
« Reply #8316 on: Fri, 09 June 2017, 19:34:21 »
A Novatouch!
Offline rmendis
  • Artisan addict
« Reply #8317 on: Sun, 11 June 2017, 16:37:19 »
Just tried one on a friend's sky dolch board this weekend, and it looked good. Glad to see it on your's!!
Offline Koatl
  • Kozahtli on reddit, etc.
« Reply #8318 on: Fri, 16 June 2017, 23:53:10 »
Does anyone know if the Miami Nights fugu with the pink eyes and pink spikes is a one-off? I've never seen one on mm. Really want one of those a lot.
Offline rmendis
  • Artisan addict
« Reply #8319 on: Fri, 16 June 2017, 23:54:54 »
Where did you see it? There is a miami nights fugu coming with GMK Miami Nights from Oco, but it's not released yet.
Offline Koatl
« Reply #8320 on: Sat, 17 June 2017, 00:08:51 »
Old post from ETF here, and I remember seeing it somewhere else too. Perhaps in a catalog of fugus. See below.
Didn't know about GMK Miami Nights. Thanks!
For the fallen homies
Offline ArchDill
Re: Nightcaps: Poisoned Summer....coming soon...
« Reply #8321 on: Sat, 17 June 2017, 01:01:51 »
ooooohh.. INTERESTED
Offline badchad
« Reply #8322 on: Sat, 17 June 2017, 01:04:53 »
Could this sale mean my first eggface?!?!?
BAD
Offline Waateva
« Reply #8323 on: Sat, 17 June 2017, 07:03:22 »
It's about time someone did some Poison-themed artisans!
Offline rotciveel
  • Fugu Curator Extraordinaire
« Reply #8324 on: Sat, 17 June 2017, 07:14:16 »
Poisonnnnnn
On mobile - excuse any typos.
Offline wishful_cynic
« Reply #8325 on: Sat, 17 June 2017, 07:45:03 »
Venomous toothies?
Offline noobas4urus
  • Mod Munky of another realm
    • The Mod Zoo
« Reply #8326 on: Sat, 17 June 2017, 11:21:58 »
Ish
"You miss 100% of the raffles you don't enter."
-Wayne Gretzky
Offline rmendis
  • Artisan addict
« Reply #8327 on: Sat, 17 June 2017, 12:22:12 »
Venomous toothies?
Ayyy! That would be killer.
Poisonous Puppets?
Offline iliptikal
« Reply #8328 on: Sat, 17 June 2017, 23:18:08 »
Oh yes. More Fugu? Puppets? :thinking:
Sent from my SM-N920W8 using Tapatalk
Offline RELLIK
  • WTB Bro Power Core WASD Set...Still...
« Reply #8329 on: Sun, 18 June 2017, 00:52:17 »
So toxic after Honeywell?  :D
     KUL-87        FC660M       Filco MJ2
Offline darwinmclovin
  • Crivens!
Re: Nightcaps: Poisoned Summer: Day 01
« Reply #8330 on: Tue, 20 June 2017, 14:49:46 »
Glam toothies? Yes , please!
“We play and are played and the best we can hope for is to do it with style.” Sir Terry Pratchett -GNU STP -
Offline Waateva
« Reply #8331 on: Tue, 20 June 2017, 15:21:57 »
 :blank:
Offline iliptikal
« Reply #8332 on: Tue, 20 June 2017, 15:22:32 »
Day 1! It's happening
Offline ashwinv11
  • give me foog
« Reply #8333 on: Tue, 20 June 2017, 15:37:31 »
HYPEEE
Offline asianboy30354
« Reply #8334 on: Tue, 20 June 2017, 15:46:48 »
omg its happening!! so hyped xD
Offline brianjking
  • always carry a towel.
    • @brianjking
« Reply #8335 on: Tue, 20 June 2017, 15:48:17 »
I bet that this sale will have keycaps and will sell out quickly.
Sent from my ONEPLUS A3000 using Tapatalk
Offline iliptikal
« Reply #8336 on: Tue, 20 June 2017, 15:49:16 »
Insider info right here lol
Offline badchad
« Reply #8337 on: Tue, 20 June 2017, 15:50:16 »
Debatable, brian.
BAD
« Reply #8338 on: Tue, 20 June 2017, 15:56:50 »
well when i break my F5 key ill need an artisan to replace it so this is perfect c:
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #8339 on: Tue, 20 June 2017, 16:03:23 »
whats all the hubub
Offline theasian
« Reply #8340 on: Tue, 20 June 2017, 16:04:45 »
whats all the hubub
Canary has put us on notice ;)  (check first page/first post)
Offline donut_sauce
« Reply #8341 on: Tue, 20 June 2017, 16:52:07 »
so this is where I start continually refreshing r/mechmarket right? (as if i don't already do that all day long anyway)
Offline oscdawg
« Reply #8342 on: Tue, 20 June 2017, 16:53:40 »
Sent from my SM-G900V using Tapatalk
Offline Tally810
« Reply #8343 on: Tue, 20 June 2017, 16:56:29 »
Summer games begin
Offline swangful
« Reply #8344 on: Tue, 20 June 2017, 17:03:42 »
Anddd its gone
Offline Meitachi
  • Je sui prest
« Reply #8345 on: Tue, 20 June 2017, 17:04:06 »
Holy cheeseballs, that was fast :eek:
Offline theasian
« Reply #8346 on: Tue, 20 June 2017, 17:04:53 »
Day 1 Micro Batch = Surgical Shine Job   :cool:  no win for me haha
Offline donut_sauce
« Reply #8347 on: Tue, 20 June 2017, 17:06:17 »
and this is when I go buy another 4x4
Offline swangful
« Reply #8348 on: Tue, 20 June 2017, 17:09:53 »
LOL!
Offline diiiP
« Reply #8349 on: Tue, 20 June 2017, 17:10:25 »
jeez, sold out after one minute...
Note to self: next time dont prooferead email and username, just hit submit...
