Author Topic: GMK Database  (Read 526812 times)
Offline duckboi
Re: GMK Database
« Reply #200 on: Mon, 08 April 2019, 12:10:27 »
Before I work on this anymore, I would appreciate some feedback: https://docs.google.com/document/d/171DXzDBXFZZ1RoWNcoDOi7_a4BUSELYXqzGHL0ArOlE/edit?usp=sharing
I should note that I contacted GMK/Uniqey and hopefully soon they will provide me with some details that I am lacking at the beginning of the document.
I also worked with Jsaint to design GMK Monochrome, if you could add that  :p
The m0ar empty you feel,  the m0ar space for Keycaps..
Offline juliandoucette
Re: GMK Database
« Reply #201 on: Wed, 17 April 2019, 16:15:11 »
Thank you for this. I found it very helpful.
Offline lightsout714
Re: GMK Database
« Reply #202 on: Mon, 22 April 2019, 17:00:35 »
Thanks for this, I enjoyed looking through all the various sets over the years. Brought back memories of stuff I used to lust over but could never afford.
Re: GMK Database
« Reply #203 on: Sat, 18 May 2019, 14:14:10 »
Have been lurking and using this for a while, thank you for this!
E6-V2 [Tealios] | RAMA M60-A [Zealios] | QXP [Healios]
Offline Warrenified
Re: GMK Database
« Reply #204 on: Sat, 08 June 2019, 17:17:02 »
What a great tool! Especially helpful for those who are designing sets and want to make sure they're not making anything too similar to sets that have run already!
Re: GMK Database
« Reply #205 on: Wed, 03 July 2019, 12:18:21 »
Fixed for most. The ones that are left I believe were inspired by actual keysets, though hold an element of originality. Although I already had that specified for skidata.
Btw. if we speak about IvanIvanovich then afaik he is the designer of GMK Miami Nights.
https://geekhack.org/index.php?topic=71507.0
Too bad he run away with all that money from people.
Correct (on both accounts :( ).  @Vloshko, are you still updating the list?  I see that you aren't active since April 2019.  :-/
Offline tobiasvl
  • ISO 9995
Re: GMK Database
« Reply #206 on: Fri, 19 July 2019, 15:58:47 »
Wasn't there a Google document which was a bit more updated? Maybe it was posted in this thread too and I just missed it?
Would be really nice to have an actual website or something with a GMK database where people could submit stuff, and where you could filter by colors, kits included, etc.
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
Re: GMK Database
« Reply #207 on: Fri, 19 July 2019, 16:19:30 »
Apart from GMK, there are more references in this thread
https://geekhack.org/index.php?topic=101433.0
Offline tobiasvl
  • ISO 9995
Re: GMK Database
« Reply #208 on: Sat, 20 July 2019, 11:18:00 »
Yeah, that was probably what I remembered. Apparently the website idea was also from there, haha.
Re: GMK Database
« Reply #209 on: Tue, 23 July 2019, 10:43:21 »
OP has been updated!
New link is up, pointing to the new web-based database.  :thumb:
I believe there is still some content that needs to be added, and that Vloshko and Matrix will be asking for some user input to complete the database.  I don't know the exact details of that, however, so I'd reach out to them if you'd like to contribute (or perhaps they will post here).
Re: GMK Database
« Reply #210 on: Tue, 23 July 2019, 11:02:52 »
Whoa.
Offline nuclear_wizard
Re: GMK Database
« Reply #211 on: Mon, 05 August 2019, 18:20:04 »
Great resource!
If it's still being added to, I don't think GMK Heck Keys from DonutCat are listed on there.
