Author Topic: How to install PCB-mounted cherry stabilizer to plate?  (Read 3583 times)
Offline Akamig
  • It's A-ka-meegh, Not AKA Mig.
« on: Wed, 10 February 2016, 10:08:12 »
Yup, I know this question is stupid.
anyway, after 2 week I recieved stabs, building a phantom now, tried to sqeeze in it about 1 hour and realized this stabilizer is for PCB, not for plate.
It's pretty frustrating, but I think there's other way to use it on plate like PCB-mounted MX Switches can be used with plate just cutoff the stems.
but If I cut this stabs wrong way, I definitely have to wait 2 moar weeeeeek... so I can't try it without any certainty.
Not Aka"MLG 360 NO SCOPE GET REKT" either.
http://steamcommunity.com/id/Akamig/
Re: How to install PCB-mounted cherry stabilizer to plate?
« Reply #1 on: Wed, 10 February 2016, 10:26:12 »
Nope, there is no way to adapt a PCB mount stabilizer housing to attach to a plate. You'll need to get actual plate mount stabs if you want to mount them to the plate.
Offline Akamig
« Reply #2 on: Wed, 10 February 2016, 10:47:40 »
Oh.... thanks for the answer! well, then It's better to use them for replacing G80-3700's rusty stabs.
All I need to do is order them and experience 2 weeks of extreme anxiety.
