Author Topic: I need some good alps boards linked to me.  (Read 2432 times)
Offline ANightOnCloudNine
« on: Fri, 12 February 2016, 01:57:19 »
I'm gonna bookmark some for later cause i'll buy one in the future.
Offline tronbeaver
Re: I need some good alps boards linked to me.
« Reply #2 on: Fri, 12 February 2016, 08:35:18 »
He means he doesn't want to use google.
« Reply #3 on: Fri, 12 February 2016, 11:46:36 »
basically, and i dont know where to start cause i dont know anything at all about alps other than they're high quality af
« Reply #4 on: Fri, 12 February 2016, 11:48:45 »
Everything is subjective. Even the "best" have some who don't like 'em much. You'll just have to research and test for yourself.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #5 on: Fri, 12 February 2016, 12:16:06 »
Start off with a (complicated) white Alps boards, they're cheap, common and fairly representative of the family. Make sure the board isn't dusty, dirty or in bad condition; it affects Alps much more than other switches. Should be plenty easy to find one, no reason to demand others "link" boards for you :P .
