Author Topic: Ergodox - left hand not working  (Read 1702 times)
Offline sitch
« on: Fri, 12 February 2016, 05:04:20 »
Hi, my right hand is all good but left hand is completely non functional
I have checked the TRRS connection and diodes all is good, is there anything else should I be checking?
Could it be the teensy having problem? but I think that should affect the right side too if teensy the problem?
http://imgur.com/a/5l2Jv
Thank you
« Last Edit: Fri, 12 February 2016, 09:41:42 by sitch »
