Author Topic: is this M13 a buckling spring?  (Read 3224 times)
Offline ricercar
  • mostly abides
« on: Wed, 02 December 2009, 15:07:10 »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=11193&item=140363581010
is this M13 a buckling spring? Does "M" always mean BS?
Offline ch_123
« Reply #1 on: Wed, 02 December 2009, 15:08:03 »
Yep, I'm typing on one right now. Even got it from the same seller.
Offline ricercar
  • mostly abides
« Reply #2 on: Wed, 02 December 2009, 15:08:59 »
thx for the lightning fast reply.
Offline ch_123
« Reply #3 on: Wed, 02 December 2009, 15:12:33 »
Ha, I think I opened the index just when you made your post. Lexmark didn't make many rubber dome Model Ms except for the white 101-key whose part number begins with 71G...
Offline ch_123
« Reply #4 on: Wed, 02 December 2009, 15:13:13 »
Quote from: webwit;138105
I've never seen one with a black trackpoint before:
http://cgi.ebay.com/IBM-Model-M13-Trackpoint-Keyboard-13H6705-Black-409_W0QQitemZ130348961282QQcmdZViewItem
I have one, it came on a German M4-1 I bought ages ago.
I don't like the smooth caps - the finish off them wears off and they feel sticky after you use them for a while.
Offline ch_123
« Reply #5 on: Wed, 02 December 2009, 15:22:21 »
I assume they're the textured ones? They're good, but not easy to keep clean. I'd like if you could use the modern Trackpoint caps, but unfortunately IBM/Lenovo modified the design somewhere along the line to use a thicker stick.
Offline Mercen_505
« Reply #6 on: Wed, 02 December 2009, 19:00:32 »
When I bought my M4-1 I got the same pack as above, only I got two reds and one black. I put the black nub on my M13 for a few days, before finally opting to remove the trackpoint completely.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #7 on: Wed, 02 December 2009, 19:36:08 »
I don't think that's the original pointing stick.
