Author Topic: Super ultra high speed board  (Read 94356 times)
Offline chimera15
« on: Wed, 02 December 2009, 16:59:12 »
So the ultimate typing championship got me thinking that it might be possible to design a keyboard that had everything going for it for super ultra high speed input.
Overall the keyboard probably won't make a huge difference, but at the highest speeds, it could make the difference between 200 and 205 wpm.  Even a couple extra .'s could matter in a competition.
Right now I'm just brainstorming, but a couple things I've noticed trying all my keyboards.
Keys should have a small area, and have good separation.
I noticed my steampunk hack with old typewriter keys was my fastest board, most likely because of the rounded keys.
Keys should have some sort of dampening.
Keys shouldn't have a lot of friction, possibly linear switches would be preferred over clicky at ultra high speed because of the speed you're moving the key is going to bottom out anyway, and clicks and tactiles bumps don't make a whole lot of difference.
Keyboard should have n-key rollover.  This could be useful, although I'm not 100% because keypresses may be so close they could be actually right on top of each other.
« Last Edit: Wed, 02 December 2009, 17:01:26 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline chimera15
« Reply #1 on: Wed, 02 December 2009, 17:02:45 »
So far right now.  I'm thinking something like green alps switches with cream plungers, and bottom switch cases, wired onto a gaming keyboard, with keycaps that have been cut into circular shapes instead of square, maybe with some sort of rubberized, or soft silicone keytop.
Actually the rubberized/soft silicone keytop might take care of the bounce and prevent harshness to fingers, so you wouldn't need cream plungers...
« Last Edit: Wed, 02 December 2009, 17:10:31 by chimera15 »
Alps boards:
Offline erricrice
« Reply #2 on: Wed, 02 December 2009, 17:24:24 »
Something I have noticed recently about bottoming out:  When using my Cherry Black 'board, I would bottom out constantly just to make sure that I was actuating the switch so the stroke would go through.  I noticed that as soon as I stopped bottoming out and only went the actuation point once I had gotten used to it that my typing speed went up more than 20 CPM.
I think this is because the actual time that you spend pushing down the key(increased as you push the key down further) and also the time it takes your finger to come back up and get to the next key(increased if you push down further).  So I have found that not bottoming out has actually increased my typing speed with other 'boards as well once I started making an effort not to bottom out.
So no real empirical data, but it makes sense if you look at it from that point of view.
I agree thought about the linear switches, once you get to know the actuation point, you really don't worry about whether or not you have pressed it, and with some switches like white alps copies, there can be a lot of friction to the point where you think you have put enough force to actuate the key but it just doesn't because of the angle you're pressing at or just a random increase in friction for some reason.
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Mañana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline chimera15
« Reply #3 on: Wed, 02 December 2009, 18:54:32 »
Yeah. I agree, around 100 wpm, it does help your speed to try to lighten up your touch a bit and listen or feel for the bump or click, but from what I've seen and felt even at those speeds it's difficult to control how hard you hit each switch. It looks and more importantly feels  like to get past 150wpm, your hand and fingers will be moving so fast that you won't be able to keep from bottoming out, which is why some sort of padding in my theory is  an absolute necessity.  The only thing that I worry about when adding padding is that it doesn't make the key sluggish, so it's going to have to be a very thin strip of silicone if I use that method.
To type at 200wpm, your hands will be moving like a machine gun, it's going to be very difficult to control how much pressure you're hitting a key with.
I'd really love to even talk to or see someone type at 200wpm.  To see the board and techniques they use.  It should be really interesting.
Right now I want silicone keys because the tips of my fingers are becoming sore, even if it does slow me down. lol
« Last Edit: Wed, 02 December 2009, 19:03:11 by chimera15 »
Alps boards:
Offline chimera15
« Reply #4 on: Wed, 02 December 2009, 19:40:21 »
It works! It's soft.  It's a thinly cut wafter of silicone glued onto the keycap.   roflol
It looks like hell, but feels great. lol
Alps boards:
Offline chimera15
« Reply #5 on: Wed, 02 December 2009, 19:44:29 »
It's going to be the ultimate.  A keyboard that feels like boobies!!!! roflol
Alps boards:
Offline hyperlinked
« Reply #6 on: Wed, 02 December 2009, 19:52:29 »
I don't know if this is a problem for anyone else, but I sometimes feel like I'm having difficulty retracting my fingers in time to take the next stroke when I'm typing very fast for more than 30 seconds. I almost want something that will allow my fingers to bounce off of it, but needless to say the drawback to that is that I wouldn't be able to type very long on it before sheer fatigue makes the part about registering keystrokes hard.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline chimera15
« Reply #7 on: Wed, 02 December 2009, 19:53:36 »
Quote from: webwit;138217
Macros. Why type " the " (5 keys pressed) when you can type RightAlt+t (2 keys) ? Etc.
Why not just macro the whole passage if it's a competition...  That's not the point....   Besides I think it actually takes more time to press and hold a switch in combination with another than just tap them one after the other.  There's an abbreviation in one of the passages in the competition "U.S.A." for instance, and the switching between Shift a then a comma which lets up, takes a lot of time off the overall passage.  You have to slow down and think about what you're pressing.
Moving your hand off to wherever you might have macro'd "the" or whatever word, since it wouldn't be in the main section of the keyboard, would take milliseconds off your time too.    It's probably not worth it too since "the" maybe only occurs once or twice in the average passage used.
« Last Edit: Wed, 02 December 2009, 19:59:13 by chimera15 »
Alps boards:
Offline chimera15
« Reply #8 on: Wed, 02 December 2009, 20:03:44 »
New spacebar on my hhk2 hack:
Alps boards:
Offline chimera15
« Reply #9 on: Wed, 02 December 2009, 21:10:00 »
Quote from: hyperlinked;138218
What keyboard did you use to break 120?
Alps boards:
Offline chimera15
« Reply #10 on: Wed, 02 December 2009, 21:11:30 »
Quote from: webwit;138222
Not sure about that, I use macros for the 5 most popular words in the English language on my DataHand and in speed tests I get a bump of 5 to 10wpm. If you have to slow down to think what you are pressing, you are untrained? If with an ordinary keyboard holding down the modifier is the problem, you can program it into a toggle-once key (i.e. press RighAlt, release, press t).
How fast do you type with your datahand out of curiousity?
What's the top speed anyone has reached with one?
Alps boards:
Offline chimera15
« Reply #11 on: Thu, 03 December 2009, 00:07:53 »
My new soft keycaps.  No more banging fingers into hard plastic:
I'm going to use greens for the main keys, but clicky blues for the spacebar, shift, return, and backspace.
I'll probably try these caps on my siig complicated that I've been using during most of the competition to see if I'm on the right track or not.  I may have made the surface area too small, not sure.
Right now this board is uber soft.  I used 10 shore a hardness silicone so it's not super soft, and still somewhat stiff, but still way softer than most mold making silicone.
Alps boards:
Offline hyperlinked
« Reply #12 on: Thu, 03 December 2009, 00:50:13 »
Quote from: chimera15;138226
I used a Filco-104 w/Cherry Brown. I find that I'm generally only good for around ten short tests in a row. After about ten, I start making a lot of errors because I can't lift my fingers back up fast enough. I don't remember if this was a problem before I got this board, but I also didn't try doing continuous typing tests on other boards either.
I could try switching keyboards, but that wouldn't really be reliable either. I'm so used to this board that I'll make other kinds of errors excessively on another board.
I did manage 115wpm on Keyhero using an Asus EeePC board the other day though. I was kinda surprised at the wpm when I was done. It felt like a slow board, but perhaps all that short travel added up in time savings.
Offline chimera15
« Reply #13 on: Thu, 03 December 2009, 00:50:19 »
Transferred.  I'm typing on them right now. My initial thoughts are that they're not too small.  It's definitely a different feel, but working well.  Still to see if they're as fast or faster than normal caps.  At very least my fingers aren't hurting like they were when I was jamming them into the plastic. lol
Edit:  Just from typing that I can tell I'm about the same speed as before, if not better.
« Last Edit: Thu, 03 December 2009, 00:56:01 by chimera15 »
Alps boards:
Offline chimera15
« Reply #14 on: Thu, 03 December 2009, 01:05:11 »
Quote from: hyperlinked;138252
Ah that's another idea I had, you're right.  I tried my low profile alps and I thought that maybe they did have a bit better time because they were a shorter travel.  The key layout is sort of odd with the m1242, though so, I think that slowed me down, and I didn't get as good results as I might have if they were in a more standard layout.   It's possible that a scissor switch board might actually be a much better choice for speed in general.
It's really interesting to hear you used cherry browns..  I'm really curious to test the scorpius I have coming.
« Last Edit: Thu, 03 December 2009, 01:15:05 by chimera15 »
Alps boards:
Offline chimera15
« Reply #15 on: Thu, 03 December 2009, 01:26:44 »
It's pretty clear I'm about 10-20 wpm faster with these caps.  It could also be that I got a good rest, since my last tests, but these caps feel really good.  I'm for sure not slower.
Alps boards:
Offline msiegel
« Reply #16 on: Thu, 03 December 2009, 01:43:52 »
this is a very interesting experiment :)
Offline chimera15
« Reply #17 on: Thu, 03 December 2009, 02:40:35 »
I posted a 108.6 on one of the passages I've been working on memorizing which is one of my fastest times yet, using them with my clicky complicated siig. So I know these caps are definitely not worse than normal ones.
Alps boards:
Offline ak_nala
« Reply #18 on: Thu, 03 December 2009, 03:12:53 »
Your use of silicone to buffer the bottoming out brings to mind another, if more complicated, solution already implemented many, many years ago - in a typewriter.
My Olympia SG-1s (yes, I have two now) have little individual springs under all the keycaps to help buffer the fingers when bottoming out (which you pretty well have to do with a manual typewriter to get a good key-strike). That coupled with the already silky smooth and light action (for a manual) leads to a delightful typing experience with no loss of precision that might ensue from having an overly soft surface on the top of the keycap itself.
Wonder what the effect would be on a computer keyboard. It's even possible the extra spring action might give a bit of a bounce and help the finger back up as an added benefit. I would think the keypad spring would have to be at least double the switch actuation force.
I definitely think the round keycaps are a great idea. Fewer edges to catch, as you've found. Hemispherical instead of the modern cylindrical indentations might also help, in that it would facilitate automatic centering of the fingers on the keys in all directions rather than just side-to-side. Positional feedback can be invaluable at high speed.
The older typewriter round keycaps run between 1/2" and 5/8" (but usually topping out around 9/16") in diameter, BTW. Even the newer double-shot plastic ones when more finger shaped, or even the more or less square ones (Remingtons of the 50s, for instance), were a bit smaller than modern key tops and had heavily rounded edges. All had a wonderful feel most modern board keycaps just can't match. The closest I've felt are the caps on the Displaywriter keyboard I just got :-)
« Last Edit: Thu, 03 December 2009, 03:22:22 by ak_nala »
No matter where you go, there you are...
Offline chimera15
« Reply #19 on: Thu, 03 December 2009, 03:40:56 »
Quote from: ak_nala;138271
Do you have any pictures of that spring keytop?  I'll have to look for those.  Maybe it would be possible to cut or take them off and use them with an alps switch somehow?
Yes the results I was able to get on my steampunk hack,  which uses old typewriter keys was what made me discover that the rounded keys help speed a lot.
Hmm
« Last Edit: Thu, 03 December 2009, 03:43:37 by chimera15 »
Alps boards:
Offline ak_nala
« Reply #20 on: Thu, 03 December 2009, 05:14:28 »
That's the one.
I'll have to drag out my camera for shots, and figure out how to up-end the beast without damaging the one achilles heal on the thing, the plastic paper guide (rare to have them intact) - maybe tomorrow.
However, CUT THEM OFF!?! Don't take this the wrong way, but are you nuts? That would be like chopping a 1930s Mercedes Roadster so you could put the fenders on a Honda Civic.
I suppose if you found one that was pretty well thrashed to begin with, but honestly, these were arguably the best full-sized manual typewriters ever made, and they aren't making any more of them!
That said, you can get SG-1's for under a $100 shipped on the Bay in as-found condition if you look hard enough. Not sure if the SG-3 has the same type of suspension on the caps, but they are up there too.
Though, I really think the concept is more valuable than trying to graft on from an original, IMO. I think the needs of the original typewriter and that of a modern keyboard are a little different - we would probably need something a bit springier and perhaps longer travel than the 0.5-1mm keycap spring travel of the Olympia. Just have to engineer and cast new caps after finding the right, readily obtainable, spring.
« Last Edit: Thu, 03 December 2009, 05:59:36 by ak_nala »
Offline chimera15
« Reply #21 on: Thu, 03 December 2009, 19:37:45 »
Had an idea how to make the soft keys more uniform and less likely to de-laminate with the glue I'm using, so they have a holder, not just resting on the keytop with glue.   Right now, after probably several thousand keypresses they get loose and have to be reglued. This would also make them even softer because there's more silicone in the holder to hit, not just a thin wafer.  I need to buy more antique keys though if I use this method, although it wouldn't matter what condition they were in, they could have broken glass where with my steampunk mod they needed to be perfect.
« Last Edit: Thu, 03 December 2009, 19:50:47 by chimera15 »
Alps boards:
Offline chimera15
« Reply #22 on: Thu, 03 December 2009, 19:49:36 »
Got the perfect set off ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370298611257&ssPageName=STRK:MEWNX:IT
It even has the square ones I like.  Should be awesome.
Alps boards:
Offline chimera15
« Reply #23 on: Thu, 03 December 2009, 23:15:04 »
Quote from: ripster;138562
Selectric thread here:
Ron Mingo could type super fast using just a baseball bat.  Here he is with the SF Angels.
Not quite sure what you're trying to say, but about the fastest typist in the world using a selectric...   I wonder if it is because the keys were powered that it allowed that speed, you only have to lightly hit them, where even the lightest key in a keyboard still takes some pressure not to mention time to actuate.  It may be that a standard layout keyboard with no keypress or actual switch would be the fastest.
I'm coming to the theory that actual relative keyboard speed, keyboard to keyboard is about keys design like the round ones that allow for accuracy, and the actual pressure it takes to activate each key.  If the pressure it takes to activate the key is a definite part of the formula then I'm not sure green alps will be the right choice, there may be better choices for a switch,  like nmb's, montereys, or even acers.
You mentioned how many grams it took to activate a Selectric key before right?
It may be worth time to break this down to a more analytical way, not simply by feel, and time the exact amount of milliseconds it takes to put one or a measured amount of say one word on screen.
I wonder if there's some kind of utility that could time me rather than having to do it by hand...?
A utility like that would be good to use to test layouts too.  For instance how long it takes in qwerty to type the word "the" vrs dvorak.
« Last Edit: Thu, 03 December 2009, 23:36:08 by chimera15 »
Alps boards:
Offline chimera15
« Reply #24 on: Thu, 03 December 2009, 23:38:28 »
60grams, so about the same as a white alps switch for a Selectric? I guess that equates to the same amount of travel time for your finger?   There is a difference though, there's a constant up pressure, where I seem to recall with the Selectric the switch drops away from your finger once it's actuated?
If I'm remembering correctly, that could be a big difference as far as your finger knowing there will be a letter generated, so it's able to move on to the next key faster.  I find if I lighten my touch up I do get faster, but it generates more mistakes because I sometimes will miss a character.  With the switch dropping away from your finger, there's little doubt that you got the switch activated.
It's interesting I'm getting about 115 average on this site:
http://labs.jphantom.com/wpm/
So the typing test at the competition site are really difficult.
Still looking for a site that will give me a time output for a short word though.
« Last Edit: Thu, 03 December 2009, 23:54:23 by chimera15 »
Alps boards:
Offline msiegel
« Reply #25 on: Thu, 03 December 2009, 23:51:59 »
Quote from: chimera15;138590
that's exactly what harris's ibm buckling spring patents say :D
Offline chimera15
« Reply #26 on: Fri, 04 December 2009, 00:12:16 »
Quote from: msiegel;138591
Ah that's interesting.  I hadn't thought of it that way, that clickies sort of perform that function.  But it's not the same that the pressure decreases, from the key actually physically accelerating away from your finger.
I really want to see a typing test that can read cpm, on only a few words, and that I'll be able to equate to wpm, which will let me see how fast you physically have to go to reach 200.  If I can see with one word the level, maybe I can approximate it with the rest of my typing, and see if it's actually physically possible with the keyboards I have.  Right now it's looking to me like 200wpm exceeds the capabilities of the alps switch.
Alps boards:
Offline chimera15
« Reply #27 on: Fri, 04 December 2009, 00:19:32 »
This is an interesting board:
http://www.frihost.com/forums/vt-89723.html
One guy states that 200wpm = 3.3 words per second...so damn, that's fast...  they better be small words. lol
I wonder if I'm physically able to type something like, " The boy went down to the river."  in under 2 seconds. lol  I need to try that.
I need to find a clock that will time that and automatically stop at .
Maybe I can write one in flash if i can't find it...
« Last Edit: Fri, 04 December 2009, 00:24:32 by chimera15 »
Alps boards:
Offline hyperlinked
« Reply #28 on: Fri, 04 December 2009, 00:31:26 »
Quote from: chimera15;138595
If you can't find it, it'd be really easy to write it in JavaScript. Just start the clock with your first keystroke and get the script to output your input character count once the timer hits 2 point 00.
...and I'm sure you were just joking about the short words, but in case you didn't know, the wpm count is usually extrapolated from characters per minute against an average number of characters per word. I forget the number. It's something like 5 characters per word.
Offline chimera15
« Reply #29 on: Fri, 04 December 2009, 00:34:32 »
http://speedtest.10-fast-fingers.com/
This may give me the raw data I need, it's a much more random test that doesn't throw any punctuation or strange words into the mix.  I should give me an indication of what my maximum speed on each board is and what the possibilities are.  It also gives cpm raw data.
Although this test is constant it doesn't allow memorization, so times will be relatively slower.  It also throws a flip page into it that slows me down a bit.
Acer:
Black/used:  80-85wpm
I was surprised with my speed with this board. The feeling of these switches is very much more plasticy than alps switches.  They're a lot lot lighter as well however, especially this well used one.
white/fresh/ hhk1 hack: 75-80wpm
This board was uber clicky, which feels good, but I had a lot of problems with speed with it.  This was due probably because of the strange position of the backspace, which is 1 key down from normal backspaces, which would take some time for me to get used to again.
Ibm model f: 75 wpm
I have a feeling that I got such bad scores with this board because it has the small back arrow I'm not used to, and also the space bar on my unit seems very hard to press relative to the keys, which I think is a result of me having it out of its slot for such a a long time.  I'm also no longer used to the space between the keys which is clearly different than an alps or alps like switch.
Japanese blue alps: 85wpm
 It looks like about 85wpm is my consistent average speed with it with my blue alps Japanese keyboard with about 2 words mistyped.
Cream alps, modified sig: 85-90wpm
  Another slightly above average alps switch for speed I would say.  It's nice not to bottom out so hard, and it's probably about the same speed as complicated white alps.
complicated white siig/silicone keycaps: 85wpm
 I'm about the same with my silicone keycaps on my complicated white alps siig, perhaps a tiny bit slower.  My accuracy seems a significant amount better, I missed maybe 1 word on average.
complicated white normal keycaps/big spacebar: 85-90wpm
I got up to about 85-90 with my bluetooth hack with normal keycaps which uses white complicates, whites, the same as my siig with silicone keys.  One thing I noticed here is that the extra large space-bar on it I think does help considerably.
fake white alps-old typewriter keycaps- 85wpm/good accuracy
  This board was great for accuracy, which can translate to speed overall, I almost never missed a word, but for speed I can't say it's significantly better than the other alps switches.  It's not going to get me to 200wpm.
irocks kr6820e: 85-95wpm
pretty consistent 83 wpm with my irocks kr6820e.  Lots of errors though. It has really comfortable keys at that speed though, very bouncy, short travel relatively.
Edit:  Just got a 93 with it...  Not sure I can go farther than that with it.  Maybe a bit.  I might get up to 100wpm..  It's a good kb for speed as I thought it might be.  It's domes are very much like scissor switches.
Monterey- 80 wpm
It could just be that I'm not used to this board that I'm slower. It also hurt using it after a few tests.  I bottomed out every keytouch because the click and spring in these switches are so light.
nmb/white - 85/ super accurate
 Another very light touch clicky board, this one has a more pronounced click than the monterey. They have smaller peaks than most alps which likely accounts for the improved accuracy.  My feeling is that I could probably go a bit faster with this board, maybe more in the 90-95 zone, but want to move on to others.  This is a very fast board for a mechanical so far.
Fake alps standard boards:
smk-85 - 85-90
  This is a fast board. The switch is very clicky unlike the complicated.  You know when you hit a key, very low error rate.
Siig kb1948  85-90
This board, which I tested right after the smk has a completely different feel to it, although it uses the same type of switch as the smk,  probably because of the different quality of the keycaps.  Still, about the same results, most around 88-89 zone.
I would say the irocks board is the big surprise so far.   I would guess it's about 10 wpm faster than the average boards.  Probably because of the short depression and nice rubber bounce at the bottoming out.  The only problem I had with it is that I would miss a character every so often.  That error rate would probably bring it down to average board speeds even though the switch activation was signifigantly better.
There's no jump out board that's like clearly 20 wpm better that would allow me to jump up to 200 wpm.
I'm going to try to learn dvorak using that site and bring my speed up and see if I can get clearly better speeds this way.
I think this makes clear to me that it is possible to design a board that is faster overall, but it may not be the direction I'm going.  I think silicone is a good start, and spongeness, because what's happening at 100 wpm plus is really like little collisions that need to be dampened in some way or your fingers will pay the price, not the hard plastic.
« Last Edit: Fri, 04 December 2009, 02:53:24 by chimera15 »
Alps boards:
Offline chimera15
« Reply #30 on: Fri, 04 December 2009, 01:31:30 »
Quote from: hyperlinked;138599
Well my point was with that short phrase was to see if I could get it up to a speed that would equal 200wpm to see if it's actually physically possible with a qwerty keyboard and to experience what that speed is like, even with short words let alone long ones, and how much I have to practice to actually rattle that short sentence off at 200wpm
Alps boards:
Offline DreymaR
  • Colemak forum guy
    • DreymaR's Big Bag of Kbd Tricks
« Reply #31 on: Fri, 04 December 2009, 02:18:25 »
Being such a fast QWERTY typist, I'm sure that trying to learn Colemak or Dvorak to get faster now will bring you a lot of frustration. Just a friendly warning.
It certainly seems to have worked for Barbara Blackburn, but I'm sure she put an extraordinary effort into her typing practice - she pretty much typed all day for years I think.
Better burden you cannot carry than man-wisdom much ~ Hávamál
Offline chimera15
« Reply #32 on: Fri, 04 December 2009, 02:57:58 »
Quote from: DreymaR;138616
I pretty much type all day, doing one thing or another.  If it does boost a significant amount I'm sure it'll help, especially with practiced memorized passages.   The key thing I need to know, is does dvorak's layout really improve speed, and by how much on average.  If it's 10wpm even that's still pretty significant, if it's more than that, if it's what's making 200wpm possible vrs 150 or something, then it's a must.
Alps boards:
Offline chimera15
« Reply #33 on: Fri, 04 December 2009, 03:07:04 »
I was thinking.  It might be possible to put a layer of silicone around the bottom of the green alps switch, that would at once limit the travel of the plunger, and second give a nice bounceback all at once...hmmm...I'm going to have to check that out.
Edit:
I opened a green alps switch and discovered it has the little projections in the bottom of the switch that hit cream alps bumpers, so that might be a valid way to go.  The activation leaf however goes all the way to the bottom of the case, so I don't think I can add silicone to it at least not in a soft form.  It's possible I could let it take up the back half of the switch so it doesn't interfere with the leaf....
Testing a green alps switch with a continuity meter I get continuity with the plunger about half way down.  So I think one of the keys will be limiting the plunger to that point, and so it hits softly and returns.  That's only about a 2-3 mm travel, which should be less than even the irocks board, that should equal speed since it should be a consistant mechanical hit that won't have misses unlike the rubber dome irocks board.
« Last Edit: Fri, 04 December 2009, 03:19:16 by chimera15 »
Alps boards:
Offline chimera15
« Reply #34 on: Fri, 04 December 2009, 03:27:10 »
I did it!! I managed to afix a piece of silicone between the case and the plunger on one side.  It now only goes down about 3 mm and then hits softness, activates the switch and returns!!!!!  This should be awesome! lol.
If this board doesn't give me 10-20 wpm faster, it'll sure be soft. lol Someone could type on this thing with broken fingers and not even feel it. roflol
« Last Edit: Fri, 04 December 2009, 03:29:52 by chimera15 »
Alps boards:
Offline ak_nala
« Reply #35 on: Fri, 04 December 2009, 03:44:30 »
Quote from: chimera15;138283
Hmm
Here's the underside of those keys (sorry for the dust bunnies, but at least they're not board chow ;)
Note that even the Shift Keys are sprung.
The keys on your pic were black and mine are green is the only difference as yours is a definitely a pic of an SG-1.
The spring is housed inside the double-shot plastic key caps, with a steel key shaft coming down through the bottom of a steel cup that is attached to the key bar and cradles the bottom of the spring, so the spring is trapped between the cup and the key cap. There is a slot in that key shaft that allows the key cap to go up and down (and limits the travel). It also appears to be the attachment method for the whole assembly.
I haven't measured it, but I'd say the limit of travel is around 1-2mm with a medium stiff spring action (significantly heavier than an Alps).
BTW - that's all stainless steel - shame they didn't make all the screws in the housing SS as well :(
Offline ak_nala
« Reply #36 on: Fri, 04 December 2009, 03:45:11 »
I've checked the one Olympia portable that is at hand (the others are a bit buried at the moment). It is an SM-9 from the late-60's, and it doesn't have any springs in the key caps at all (straight connection to the key bars). There are some white Olympia key caps on eBay right now, but they also appear to be from an SM-9, so won't have the springs.
I have a couple SM-3's that date from the 50's to early 60's (same time period as the SG-1's - the one I took pics of dating from around 1960) that are supposed to have some kind of spring action in them (though reportedly for leveling the keys during the key-press rather than cushioning them). I'll try to dig them up to take a look and report back.
Offline chimera15
« Reply #37 on: Fri, 04 December 2009, 03:46:59 »
I figured out rather than trying to redo another matrix on these in case these keys actually suck I'm just going to wait for the siig minitouch I have coming from Canada that I'm going to make a wireless mini from.  I'll have a spare siig minitouch pcb I'll be able to wire these greens right into then.  I'll be able to make 2 compacts at that point.  One wireless with white simplified switches and the other this speed keyboard with a siig minitouch pcb.  That way I don't have to wire any more matrix's, cause that's a pain the but. lol
Alps boards:
Offline chimera15
« Reply #38 on: Fri, 04 December 2009, 03:50:19 »
Quote from: ak_nala;138625
Wow that's really interesting, so what happens? What triggers the spring? The little locks? How does it get trapped?  I may have to really watch for one of these on ebay.  I did look them up and couldn't find any.
Alps boards:
Offline ak_nala
« Reply #39 on: Fri, 04 December 2009, 03:58:22 »
Here's one that's mis-labeled as a "portable":
http://cgi.ebay.com/OLYMPIA-DELUXE-PORTABLE-MANUAL-TYPEWRITER_W0QQitemZ220519839982QQcmdZViewItemQQptZBI_Typewriters_Word_Processors?hash=item335801b8ee#ht_500wt_1182
There were a couple more last week, but they are gone.
Note that shipping on these is pretty bad, because they are HEAVY. Gotta laugh at the above when they call it portable. Hernia inducing is more like it.
Offline ak_nala
« Reply #40 on: Fri, 04 December 2009, 04:04:46 »
What triggers the spring action is actually bottoming out. You thwack the key down to give a good, consistent registering of type on page, but instead of a sudden halt as on most typewriters, the key cap acts as a cushion.
The spring is trapped because the end of the little shaft that comes through the cup that holds the bottom of the spring has a slot in it that hooks over the end of the key bar and settles into a notch that prevents it from coming off. In that notch it is free to travel the length of its slot before the key bar hits either end. I think there is a bit more play in it at the bottom than you'd ever use in actual practice that allows just enough wiggle room to lever the shaft off of the bar for disassembly, but not enough that it would ever happen in use. Haven't tried to take it apart.
Offline ak_nala
« Reply #41 on: Fri, 04 December 2009, 04:22:46 »
BTW - The art of typing with a manual typewriter (so it doesn't kill you, that is), is to thwack down on the key with just enough force to make the type hit the platten and then back up. It's much more of a quick down-up action than you usually do on a computer keyboard - more like staccato on a piano - allowing momentum to do a lot of the work rather than just hitting the keys full force. It's much more in the wrist than when 'boarding.
And the REAL art is to do all this at speed and with nice, consistent force so all the characters are crisp and the same shade of blue-black.
Nice thing about the Olympia is it takes out any trace of the bottoming out jarring that remains even with good technique, and helps even more when you aren't hitting the keys perfectly.
« Last Edit: Fri, 04 December 2009, 04:25:25 by ak_nala »
Offline chimera15
« Reply #42 on: Fri, 04 December 2009, 04:33:16 »
Interesting.  I changed my silicone caps to my mini hhk blue alps hack and I started getting times in the 90's, from 85's before. It's possible these caps really do make a significant difference.
Alps boards:
Offline DreymaR
  • Colemak forum guy
« Reply #43 on: Fri, 04 December 2009, 06:25:35 »
About the layouts:
I don't think anyone have solid scientific evidence one way or another. But the anecdotal evidence suggests that Colemak and Dvorak will be faster once you learn them well enough. The big question is: When is that?
Dvorak promotes hand alternation, which is good for speed. Colemak has less hand alternation than Dvorak but more rolls which is also good for speed. From playing tambourine I have the feeling that rolls are the fastest way to travel - I did an astonishing 240 WPM on a simple roll test once, corroborating this theory. Unfortunately, I didn't do a similar hand alternation test so I can't compare directly. And at any rate it's not all rolls all day long so your speed total will depend on a bunch of other factors too.
Either layout should be supplemented with some alternative fingering for best speed results - just like I'm sure you're doing in QWERTY already. (Example: NK would be a one-finger digraph so when typing 'think' I slide my hand in so that the middle finger does 'n' instead of the index finger.) This is one of the things you'll have to spend effort on: Learning how every common word is best typed in the new layout, and automatizing the common words again.
If I were you, I'd go with Colemak simply because relearning fewer keys should make you faster in less time. Maybe even consider my Tarmac transitional layout to learn it one hand at a time?
Offline erricrice
« Reply #44 on: Fri, 04 December 2009, 10:21:36 »
Quote from: chimera15;138636
I think I'm going to have to try some kind of version of this.  I really think I would love it, short throw alps would be great since the actuation point is right at the top!  I think to make it a little easier though, I am just going to put a chunk below the keycap on both sides to stop the key from bottoming out.  Probably not as effective, but meh I'm just trying it for now.
BTW, where might you come across silicone like that?  I have no experience with this kind of thing so I have no idea where to even start.
Does anyone know what the usual key travel is on laptop(scissor) keyboards is?
Logitech G5[/FONT]
Offline chimera15
« Reply #45 on: Fri, 04 December 2009, 11:14:50 »
Quote from: erricrice;138720
I'm using ecoflex from smooth-on:
http://www.smooth-on.com/
The bouncy keys are a wonderful feeling.  I'm considering making a sheet of silicone and making some kind of tool that will cut normal key shaped pieces of silicone out to glue to the tops of my normal keys. heh.  It may not improve speed, but the feel is so much better than hard plastic, and I think I've proven at this point that it doesn't hurt speed.
« Last Edit: Fri, 04 December 2009, 11:17:34 by chimera15 »
Alps boards:
Offline chimera15
« Reply #46 on: Fri, 04 December 2009, 11:28:18 »
Quote from: ripster;138699
I still like the keyfeel of a Selectric.  Whiiiiiiiirrrrrrr......  SLAP.  Someday on Ebay I'm hoping one of the rare Selectric Terminal INPUT (not printer) ones like in this link.
It is a cam driven 110VAC motor that does all the work and your fingers just glide along hippity hoppity.
So in other words - if you want the ultimate FAST keyboard you have to motorize it.
I know, I was thinking about a motorized keyboard for a long time now, but I don't see any feasible way to do it unless I really get into the mechanics of electrics and find some way for the arms to actuate a keyboard switch instead of typing a letter. lol I think that'd be the easiest way to make a prototype.
I spent almost all day today typing on that darn test and didn't break 103 wpm all day.  I can't even reach my high score yesterday which is frustrating.
At this point I've started trying to learn dvorak more.  I'm still gaining speed but still in the low teens or high single digit area for speed. My thought is this has to be the key to get a lot closer to 200.  Qwerty just isn't cutting it. Even if I do a perfect run on the shortest of passages my speed doesn't go past 120.  For 200, there's no way I physically can do it.  It would be a whole nother two or three levels beyond what my hands are capable of moving with my current boards.
I hope the green alps will take me up another step, and the dvorak will take me up at least another step, at least then I should hopefully be in the 120-130 average range.
My mantra right now is, "What one man can do another can" from "The Edge" lol There's just something I'm missing. lol
« Last Edit: Fri, 04 December 2009, 11:31:09 by chimera15 »
Alps boards:
Offline hyperlinked
« Reply #47 on: Fri, 04 December 2009, 12:13:28 »
Oh yeeeeah! Who needs a clicky keyboard when you can have a slammy keyboard? I had forgotten how "easy" it felt to type on those things. Whoever brought up the short travel of the Seletric keys, thank you! It's a fond memory I had forgotten about.
"whuk-KLAM... whuk-KLAM-KLAM-KLAM...whuk-KLAM... whuk-KLAM"
Offline chimera15
« Reply #48 on: Fri, 04 December 2009, 18:22:52 »
My thought is that the Selectric allows for faster typing right now.  I'd really like to try one again.  I was thinking though, is there a physical difference and different movement anywhere in the typewriter that would allow for the placement of an alps switch to be depressed on all the keys?
Edit: Actually you might not even need to introduce a switch somewhere.  All you need is someplace where two pieces of metal might come together on the individual letters somewhere were it wasn't before.  You could use that like a switch too.
« Last Edit: Fri, 04 December 2009, 18:52:35 by chimera15 »
Alps boards:
Offline chimera15
« Reply #49 on: Fri, 04 December 2009, 18:31:09 »
Oh I didn't read that link.  So there's a conversion kit for selectrics?  How would that work I wonder?  All you need is to be able to turn the keypresses into a switch somehow, and I would be able to rig a matrix to it...
I need to reread your explanation of how the selectric generates a keystroke again.  Is there already a part that acts as a switch?  As I recall it uses cams to decide what key has been activated?
« Last Edit: Fri, 04 December 2009, 18:54:35 by chimera15 »
Alps boards:
