Author Topic: How to find keycap sets? -- Looking for blank, thick beige PBTs.  (Read 3643 times)
Offline Wulfre
« on: Sat, 13 February 2016, 14:54:22 »
Keycaps are a fairly niche market, so I have no idea where to look in order to find quality sets -- especially specific colors or layouts. It seems that the market is so small that you can only find what you are looking for if you get lucky because there is no one place that keeps a large stock of everything.
Right now I am looking for thick (which I have come to understand as ≥1.5mm) PBT keycaps in a beige color, in standard measurements (CM QFR), without any printing on them.
Offline darkclone24
Re: How to find keycap sets? -- Looking for blank, thick beige PBTs.
« Reply #1 on: Sat, 13 February 2016, 14:58:05 »
RS84 67g Zealio Purple | Choc Mini MX Black | WASD V2 MX Clear | Golbat 78g Zealio Purple | Duck Octagon V2 MX Clear
Offline Wulfre
« Reply #2 on: Sat, 13 February 2016, 15:00:28 »
https://geekhack.org/index.php?topic=78563
You've not looked very far!
I've definitely taken a look at that thread before, I just don't really want to wait 2+ months for my keycaps to be processed and shipped. The only reason I would participate in a group buy is if there is an exclusive/designer keycap set, of which do not really interest me at the moment anyway.
« Reply #3 on: Sat, 13 February 2016, 15:03:09 »
Well that is probably your only option to get what you want.
Offline darkclone24
« Reply #4 on: Sat, 13 February 2016, 15:09:43 »
Well, you can look at buying some EnjoyPBT through a Tao Bao agent.
UKKeycaps do a Grey and Beige set: http://ukkeycaps.bigcartel.com/product/gateron-thick-pbt-blank-keycaps-iso-ansi
But they're on pre-order, so you're waiting again.
Honestly, that group buy is your best bet. Nothing in this hobby is instant when it comes to aftermarket or custom parts. The keyset your after is basically exclusive anyway, so I'm not sure what the problem is.
Offline Hellcatz
« Reply #5 on: Sat, 13 February 2016, 15:09:58 »
2 month is pretty much nothing in the geekhack community. Most gbs norm take 6 months or well upto a year.
Offline Wulfre
« Reply #6 on: Sat, 13 February 2016, 15:26:27 »
Alright, thank you for reminding me of the group buy then. I guess I'll join in and wait it out, it will be worth it in 2 months time.
« Reply #7 on: Sat, 13 February 2016, 17:45:59 »
A certain amount of patience is required when buying keyboard bits.
Some keycap sets are available of the shelf, but only if someone has had the forethought to get a bunch of sets manufactured ahead of time and keep them in stock (kinda expensive to do).
Otherwise just join a GB, and exercise patience as unexpected delays do happen as rel life intrudes on what, for most, is a hobby :)
