Author Topic: I made something!  (Read 3491 times)
Offline TheRavenDog
I made something!
« on: Tue, 16 February 2016, 16:08:11 »
It's super simple and super geeky: my new name plate at work.
I'm going to TAP plastic to get a clear base plate so you can see the keys actuate.
The dream...                     The reality...
Offline xondat
  • i'm not a star
Re: I made something!
« Reply #1 on: Tue, 16 February 2016, 16:11:32 »
Pretty cool, what switches do they reside on?
Offline TheRavenDog
« Reply #2 on: Tue, 16 February 2016, 16:13:14 »
IBM Model M barrel assembly with Model F paddles. Nice and loud.
Offline 0100010
  • Not Sure
« Reply #3 on: Wed, 17 February 2016, 17:06:30 »
Stop giving me ideas.... :-p
Offline piemancoder
« Reply #4 on: Wed, 17 February 2016, 19:46:09 »
I need to learn how to do this. Amazing job  :thumb:
Yoda grammar best has
Offline TheRavenDog
« Reply #5 on: Wed, 17 February 2016, 20:09:41 »
It was super easy.
Here's what I did.
- Start with a PC122 Model M
- Cut all the rivets (like a BoltMod)
- With a sharp knife cut off the F1-F24 part of the barrel assembly. For my name I only needed 22 characters.
- Before you put in the paddles, secure (with little bolts) the barrel assembly to your name plate. TAP plastics can make a clear name plate for about $8.
- Un-bolt the barrel assembly from the name plate.
- Put in all the paddles.
- Re-bolt the barrel assembly to the name plate (very carefully).
- Put in your key stems.
- Put on your key caps.
Offline berserkfan
« Reply #6 on: Thu, 18 February 2016, 10:30:00 »
um, so this doesn't actually do anything except look good?
 :eek:
May I suggest adding an LED strip then, just for fun?
Offline regack
« Reply #7 on: Thu, 18 February 2016, 10:49:37 »
 :eek:
A LiPo battery, a Pro Micro, some LEDs.... yessss....
