Author Topic: Anyone have QMX clips and SA keycaps?  (Read 2290 times)
Offline ika
« on: Tue, 16 February 2016, 20:55:39 »
I've been on the verge of dumping all my SA sets just because I don't like the sound they make when they bottom out, but I like the feel a lot so I've been waffling on it. I just had a genius thought, how would SA caps sound on QMX-clipped switches? If they are as silent as GMK advertises, this might be my ticket to SA goodness. Anyone have both of these things and a way to compare? Thanks!
Offline Giorgio
Re: Anyone have QMX clips and SA keycaps?
« Reply #1 on: Tue, 16 February 2016, 23:47:38 »
The upstroke is silenced, whatever the keycap. For the downstroke you could possibly add some orings that will work impacting the clip. You will need many of them, there is a guy in gh that sells the thick version (probably lwlp)
You could for example combine one thick and one thin oring.
