Author Topic: No prizes for guessing what this is the master for...  (Read 3069 times)
Offline __red__
« on: Thu, 18 February 2016, 00:30:28 »
Only issue is that it is slightly sharp on activation.
Interestingly, that's sized for tall spherical so the smaller sizes should be significantly easier...
Offline 3K
Re: No prizes for guessing what this is the master for...
« Reply #1 on: Thu, 18 February 2016, 02:11:19 »
I'm very interested...
Just curious how the 2u+ caps will fit.
Offline asdfjkl36
  • blue shirt guy
« Reply #2 on: Thu, 18 February 2016, 02:55:34 »
O.O
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Thu, 18 February 2016, 03:13:38 »
The future looks brighter everyday  :cool:
« Reply #4 on: Thu, 18 February 2016, 03:24:51 »
Now that is interesting!
« Reply #5 on: Thu, 18 February 2016, 07:48:39 »
How much higher than normal does it end up?
What about all those different "profiles" that Cherry caps come in?
- D Trump 2026-10-24
Offline __red__
« Reply #6 on: Thu, 18 February 2016, 08:52:46 »
About 1mm with the tall profile. With "normal" profiles it's actually lower but I'd build a different adapter for those to deal with point zero below:
Two design issues;
0) Slightly reduced travel.
1) The actual adapter is dependent on the height of the stem.
I'm not sure solving point zero is possible without either switching (or modifying) springs or doing a one-way modification to the mx cap which is something many may not want to do.
To solve point one I've been experimenting with an insert for the barrel and a sleeve for the stem.
The latter allows you to calibrate the height, the former may be needed to make the latter possible.
Lastly, I'm pretty close to just saying "screw it" and just making a new barrel design but of course that's only useful for F peeps.
Red
Offline RoastPotatoes
    • RoastPotatoes Keyboard Blog
« Reply #7 on: Fri, 19 February 2016, 09:14:03 »
Anything further? This is very interesting. Are you going to be making a lot and would it be possible to get one?
Offline __red__
« Reply #8 on: Fri, 19 February 2016, 18:50:15 »
I want to avoid casting if I can so now that I know the shape will work I'll be looking toward CNC.
I have time booked on a CNC machine but right now I'm seriously putting thought towards making a machine to mill it.
It's actually not that hard.
