Author Topic: New case/board design - looking for help with a few things  (Read 3995 times)
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« on: Fri, 19 February 2016, 04:04:37 »
So I initially had a much more complicated design planned for the case and this was just one part of the whole case. Anyway here is a rough first sketch. Was looking for some help and advice from people who might have made a case in the past, or just know the ins and outs. Seeing as how this is just an idea, no specifics yet.  :thumb:
If you have some time to kill, or youre just bored, shoot me a pm
« Last Edit: Sat, 20 February 2016, 14:00:53 by DaleSnail »
Offline theoriginal123123
Re: New case design, looking for help with a few things
« Reply #1 on: Fri, 19 February 2016, 04:42:43 »
You might want to look into using Swill's plate builder, it'll give you a plate with the switch cutouts and basic dimensions, then you can build off that.
It think it looks alright so far, are you just going for the bent plate/exposed bottom look?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #2 on: Fri, 19 February 2016, 04:52:09 »
Yeah, just going for bare bones, clear acrylic housing with an aluminum back piece for lift. it was a part that fit into a weighted aluminum bottom piece for the initial idea.
Ill start trying to work the  Swill layout editor tomorrow after some sleep haha. Just need to find someone whos had some acrylic and aluminum stuff made so I can get  some info on that.
« Last Edit: Fri, 19 February 2016, 04:54:15 by DaleSnail »
Offline TalkingTree
    • My projects
« Reply #3 on: Fri, 19 February 2016, 05:15:12 »
What keyboard size would it be for?
« Reply #4 on: Fri, 19 February 2016, 05:15:52 »
I have a case that looks completely different on top, but I made the back foot as one long edge that touches the desk at an angle like your design.
I cut a groove in the centre for the USB cable. After plugging the cable, I covered it in U-profile rubber edge trim, specifically this one (The page is in Swedish, but there is an image) from a local store that specialises in rubber products. You should be able to find something similar in your town or on eBay. I also cut a smaller groove in the U-trim - and with the cable in there I think that should prevent the trim from sliding sideways.
Your design looks too flat. If you plan to build the bulk of the case of flat layers with cut holes in them, then you would need at least three layers: one layer for the plate, one layer for giving room inside and one bottom. Don't underestimate the space you will need for the switch pins or the controller.
You could perhaps give the controller even more room by cutting off parts of the top plate that will be covered by the L-bracket.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #5 on: Fri, 19 February 2016, 11:28:52 »
I was thinking tkl, but if it makes to an IC then I will most likely let people decide between 60% or tkl (I kind of want to do a 75% bt I feel like it would look odd on this)
That was the plan, I am just terrible at drawing to scale haha. The acrylic would be similar to something like Gon's crystal cases (short top plate, taller middle peice, and flat acrylic on the bottom).
I like shortening the top plate to make it a bit thinner, so Ill probably go with that.
Offline TalkingTree
    • My projects
« Reply #6 on: Fri, 19 February 2016, 13:02:06 »
There's plenty of cheap 60% cases around; 75% would be interesting.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #7 on: Fri, 19 February 2016, 13:10:58 »
If I did go 75% I think id try and go full keyboard kit, or at least case + pcb.
Offline TalkingTree
    • My projects
« Reply #8 on: Fri, 19 February 2016, 13:15:53 »
PCB, interesting. What layout do you have in mind for shift keys and bottom row?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #9 on: Fri, 19 February 2016, 14:04:27 »
Nothing set in stone really, Heres one I put together a while ago. Not exactly 75%, but i dont really like having the dedicated FN keys
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #10 on: Fri, 19 February 2016, 14:55:09 »
or maybe even this
Offline user 18
« Reply #11 on: Fri, 19 February 2016, 14:57:30 »
or maybe even this
Looks like a whitefox (vanilla).
Avatar by ashdenej
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #12 on: Fri, 19 February 2016, 15:01:36 »
or maybe even this
I had actally never seen a Whitefox before, now i feel less creative haha
Offline user 18
« Reply #13 on: Fri, 19 February 2016, 18:58:24 »
or maybe even this
Well, you do have a slightly different logical layout. Not saying it as criticism, just making sure you're aware.
Having dedicated function keys would probably make a difference in terms of distinguishing your board from the fox.
Avatar by ashdenej
« Reply #14 on: Sat, 20 February 2016, 07:37:22 »
BTW, in my own very personal subjective opinion, I think that
1. You should make the edge of the keys on the left and right sides be flush with the edge of the plate/case.
2. There should be a raised edge at the front border, like there is at the back.
... Only because I dislike the look of exposed switches with fat borders.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #15 on: Sat, 20 February 2016, 14:05:39 »
Well I was thinking no borders at all on the acrylic. But on the front, do you mean like a smaller version of the back or like a lip?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #16 on: Sat, 20 February 2016, 14:07:39 »
or maybe even this
Maybe something like this?
Guess ill be on the hunt for someone to help with a PCB design soon enough
« Last Edit: Sat, 20 February 2016, 15:50:26 by DaleSnail »
