Author Topic: SURVEY: Your keyboard layout switching experience  (Read 23751 times)
Offline fleischverpackung
« on: Fri, 19 February 2016, 05:10:33 »
Hi there you typing enthusiasts!
I am interested in your hands-on experience while switching to DVORAK, COLEMAK or what else is out there.
This should not start a discussion about which is best or what switching to is worth it.
I hope this thread could be informative for others considering learhing another layout.
I am intrested in:
# language
# what you are using your pc for (programming/writing/office/graphics)
# average and max wpm QWERTY speed before switching
# how long you've been touch typing QWERTY
# the time you put in relearning
# your new wpm speed over time
# your QWERTY speed after switching
« Last Edit: Sun, 21 February 2016, 03:23:26 by fleischverpackung »
Offline domsch1988
Re: Your keyboard layout switching experience
« Reply #1 on: Fri, 19 February 2016, 05:35:49 »
Just too answer your questions shortly:
- German
- Mostly office and some writing/browsing
- 65 avg 82 max
- 4 years
- 9 hours a day (not sure if i got that question right...) since 3 days
- 32 currently and increasing
- untested (i just started and don't want to make it harder by going back and forth)
Offline stevep
    • Colemak Mod-DH
« Reply #2 on: Fri, 19 February 2016, 11:11:07 »
#language
English
Mainly programming
I only did a couple of tests before switching, was around 50-55 wpm, but not using the "proper" technique
never learned
practised daily, took about 2 or 3 months to be comfortable, learned to properly touch-type simultaneously.
70wpm
I have switched. I don't need no steenking QWERTY.
« Last Edit: Fri, 19 February 2016, 11:17:55 by stevep »
Offline iaeen
« Reply #3 on: Sat, 20 February 2016, 07:15:58 »
#language
English
#What you are using your PC for
Mostly programming and general office work. Also surfing the internet.
#average and max wpm QWERTY speed before switching
maybe 25-30 hunting and pecking
#how long have you been touch typing QWERTY
Never. I tried to learn touch typing several times. I never succeeded until I made the switch to Dvorak.
#the time you put into relearning
It took me maybe a month before I got really comfortable. About two weeks after I switched (at about the time I was committed and couldn't easily go back), I had to write up my senior design report for engineering school. That was painful, but a couple overnighters spent typing with a hard deadline was a great motivation to pick it up faster.
#your new wpm speed over time
I'm averaging about 45wpm right now. I should mention that I don't consider myself to be a very good typist; I'm just happy that I can type.
#your QWERTY speed after switching
I avoid QWERTY at all costs. I would probably struggle with 10 wpm now.
ErgoDox Infinity
Offline steve.v
« Reply #4 on: Sat, 20 February 2016, 11:29:14 »
I am intrested in:
# language
English
Programming/Writing
130 wpm highest
15 yrs
3 months to learn Colemak @60 wpm
80 wpm avg now (1.5 year)
10 wpm / 40 wpm (mobile thumbs)
Offline chroness
  • HHKB Fanboy
« Reply #5 on: Mon, 22 February 2016, 23:40:45 »
I am intrested in:
# language
English
Programming/Writing
130 wpm highest
15 yrs
do you have any recommendations for mobile typing speed tests? I'd be curious to know mine.
Cup is love, Cup is life
Offline Zustiur
Re: SURVEY: Your keyboard layout switching experience
« Reply #6 on: Tue, 23 February 2016, 06:14:56 »
English
Home PC is a bit of everything including some gaming. Also use colmak at work
70wpm before switch
about 20 years of touch typing QWERTY
About 4 weeks of focussed relearning
Current WPM unmeasured but probably around 50-60, which is enough for most things I do
QWERTY speed on a good day is still around 70 wpm, but edging slower as I use it less and less. On a bad day. Probably about 20 wpm as my mind rebels. It seems to depend almost entirely on location rather than anything else. If I'm at a desk where I've used colemak, then QWERTY is hard, but if I go somewhere else entirely QWERTY is totally do-able.
Offline steve.v
« Reply #7 on: Tue, 23 February 2016, 21:53:04 »
I am intrested in:
# language
English
Programming/Writing
130 wpm highest
15 yrs
easy; http://play.typeracer.com
Offline Fiery
  • Click Clack Clock and a nice Thock
« Reply #8 on: Wed, 24 February 2016, 00:56:05 »
# language
Norwegian
a bit of everything, but mostly writing and browsing
45-50~
1+ years properly
2 months, first month half switch and second full switch
up to 40wpm
basically gone
TP4 fanboy
« Reply #9 on: Wed, 24 February 2016, 04:41:57 »
I've switched to Dvorak for a bout a year now and I'm pleased I did. I couldn't touch type before I changed layout, so my data isn't super accurate and I suspect learning to touch type had more of an affect for me.
- Language: English (UK QWERTY, switched to US Dvorak)
- PC Use: Programming and Office work.
- WPM before switch: not sure, but ~40wpm avg and ~50 max
- QWERTY touch typing: Never touch typed before.
- Learning time: ~2hours a day for 2 weeks, then full switch (~9-10 hours a day). Competent after 3-4 weeks.
- New WPM: 55-60 and growing
- New QWERTY speed: ~35-40 wpm
I have a post here where I'm going through and dissect my Dvorak learning experience in more detail.
Offline tuffff
« Reply #10 on: Sun, 28 February 2016, 15:57:04 »
# Language: German (QWERZ, switched to Neo 2 4 years ago, will be switching to custom BU-TEK as soon as my planck arrives)
# PC Use: Programming and some gaming
# WPM before switch: ~60 wpm
# QWERTY touch typing: 2 years but with bad habits
# Learning time: Switched completely and suffered for ~2 weeks. Speed acceptable at ~4 weeks, 4 layers in muscle memory ~4 months
# New WPM: 100 wpm currently, but reason for switching was mostly it’s much more comfortable while coding
# New QWERTZ speed: Just tested 16 wpm …
Offline yellowfour
    • Balanced Effortless Advanced Keyboard Layouts
« Reply #11 on: Tue, 22 March 2016, 06:17:36 »
# Language:
English
# what you are using your pc for:
programming, writing, office, graphics, games, multimedia, internet, storage, networking, communication, server, virtual machine
QWERTY to Dvorak
60/70 WPM
6 years
1 month
# your new Dvorak wpm speed over time
80 WPM
40 WPM
Dvorak to BEAKL
# average and max wpm Dvorak speed before switching
80/90 WPM
# how long you've been touch typing Dvorak
15 years
# the time you put in relearning BEAKL
9 days
# your new BEAKL wpm speed over time
35 WPM
# your Dvorak speed after switching
80 WPM
« Last Edit: Tue, 29 March 2016, 15:27:11 by yellowfour »
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #12 on: Tue, 22 March 2016, 07:46:03 »
QWERTY -> Dvorak (in progress)
# language
English, with some Hungarian thrown in once in a while.
Prose, programming, chat, games.
90-95 average, 110-ish top.
~15 years, or more.
4+ months, but hardly any tutorials.
50WPM and rising.
~80WPM, rapidly dropping.
Offline DvorakDachshund
« Reply #13 on: Tue, 22 March 2016, 10:32:21 »
# language: English
At the time of the initial switch, writing a LOT of emails for work. CUrrently, office work (spreadsheets, etc)
I maxed out at 60 WPM for my sped tests
Never learned to touch type QWERTY unfortunately
Took about 2 months of ~3 hours a day of typing to get up to 60WPM on Dvorak
My current speed tests are between 95-100 WPM
Around 40 WPM, since I rarely use it. If I'm somewhere away from a DVORAK board (like vacation with only my wife's laptop) I get back up to 60 WPM in a couple of days.
Offline H-Man
« Reply #14 on: Sat, 02 April 2016, 16:04:50 »
# language
English
Everything. Typing, programming, graphics, gaming, engneering work, etc.
Lets just say 30 WPM. I have hand issues.
Tried to learn for 10 years, gave up 6 years ago.
I've been DVOARK for 6 years but relearning only took 6 weeks.
I don't know or care. Switched to DVOAK because QWERTY was giving me RSI. I'm about twice as fast on DVOARK if I had to guess.
Don't know. Rarely use QWERTY.
Keyboards:
Kinesis Advantage MPC USB/QD I got for $50 [Main]
Kinesis Classic I got for $50 [Backup]
IBM model M from 1984 that I got for free. [Family gaming box]
Microsoft Ergonomic I spent too much money on. [paper weight]
Offline WestMountain
« Reply #15 on: Wed, 06 July 2022, 05:13:07 »
# Language:
English
QWERTY to Dvorak
60/70 WPM
6 years
1 month
80 WPM
40 WPM
Dvorak to BEAKL
80/90 WPM
15 years
9 days
35 WPM
80 WPM
Do you recommend switching from dvorak to beakl. is it much better?
