Author Topic: Switching from OEM to Cherry profile: what's it like?  (Read 10128 times)
Offline macguy80
« on: Fri, 19 February 2016, 16:21:03 »
It's been years since I've used a Cherry-brand keyboard, so I am curious. Pros? Cons?
Offline quasistellar
Re: Switching from OEM to Cherry profile: what's it like?
« Reply #1 on: Fri, 19 February 2016, 19:08:37 »
I prefer the lower profile, myself, but it's really not too much different. If mech keyboards came in shallower cases I would probably just use OEM, but alas, they typically do not.
« Reply #2 on: Sat, 20 February 2016, 01:31:50 »
Cherry branch keyboard, I dunno.
Cherry profile keycaps - I switch around between keyboards and profiles so often I don't really notice any more.
Offline jacobolus
« Reply #3 on: Sat, 20 February 2016, 01:38:59 »
“OEM” profile isn’t a precisely defined term, but many such keycaps have too little step between rows, which makes the top rows of keys harder to reach compared to a more aggressive profile.
The main section of a “Cherry profile” keyboard is going to be lower, which may make a very slight reduction to key wobble. The main differences (apart from the height step difference and possible differences in surface finish) is going to be to the sound. Different thicknesses, sizes, and plastic materials lend subtly different sounds to the switches.
Which one you think sounds or feels better is down to personal preference though.
For pictures, see https://geekhack.org/index.php?topic=68550
Offline FoC_Tow
  • Brokehlicious
« Reply #4 on: Sat, 20 February 2016, 23:37:52 »
Tbh I personally feel like thickness of caps makes the bigger overall difference as well.
Theres definitely a noticeable difference between cherry and oem profiles caps tho,
and even with the difference in hight and shape being rather minimal its still enough for me to pick cherry over oem in terms of look & feel.
Most people on here prefer the less tall and more pronounced shape of the classic og cherry profile, but its not to extreme of a difference that would take you long to get used to.
Also,  like already mentioned, its important to note that cherry-branded keyboard doesn't necessarily mean caps are cherry profile.
Theres many cherry-branded non-mechanical boards that are using even less tall hybrid profiles.
« Reply #5 on: Sun, 21 February 2016, 00:00:06 »
A larger difference would be felt switching between sculpted SA and almost anything else :p
Offline Jokrik
« Reply #6 on: Sun, 21 February 2016, 05:01:43 »
I can't agree more with this, for me having thinner keycaps would give a more feel of the switch
But it's all personal preference, some people can stand SA, some love DSA
But personally I found cherry profile has the best feel, and love it thin
And now my hand just can't handle oem or even any other profile, I type slower with them too and keep losing track of where my fingers are due to different sculpt
Offline swimmingbird
  • keyset hoarder
« Reply #7 on: Sun, 21 February 2016, 05:07:01 »
Just feels more natural
I went from OEM to SA before trying Cherry though so that was probably a weirder shift to do
Offline jaffers
« Reply #8 on: Sun, 21 February 2016, 05:18:03 »
Cherry profile is the best profile, it feels great. And its such a nice look as well, crisp edges and sharp corners. I think an aesthetically pleasing keycap is important because you look at your keyboard all the time
