Author Topic: Filco screw size  (Read 2326 times)
Offline awhitedev
Filco screw size
« on: Sat, 20 February 2016, 11:39:01 »
I'm building a Phantom and sourcing the parts individually. Does anyone know what size the screws are that attach the switch plate to the Filco keyboard body / frame?
I read in some other threads that the screws might be m2.5? Does anyone have a definite answer on thread size and length? I believe there's three screws that attach the plate to the body.. are they all the same?
Offline axtran
Re: Filco screw size
« Reply #1 on: Sat, 20 February 2016, 20:47:32 »
The phantom plate just has holes which use the Filco's plastic supports.
MX Silent > MX Vintage Black > Everything Else
Offline awhitedev
« Reply #2 on: Sun, 21 February 2016, 12:45:23 »
Unless I'm mistaken, the threads of the screws go through the plate and into those plastic supports. Right? So I would still need to know the proper size and length.
Offline axtran
« Reply #3 on: Sun, 21 February 2016, 12:46:45 »
Do you have a Filco case with no screws or something? They're threaded uniquely because they mount right into plastic and not an inlaid metal nut.
Offline delatroy
« Reply #4 on: Sat, 07 July 2018, 09:07:49 »
Anyone know the mm length of the M2 and M2.5 screws please?
