Author Topic: Which keycaps family are Majestouch? And G80-3000s?  (Read 5228 times)
Offline spremino
« on: Fri, 04 December 2009, 08:28:09 »
Which keycaps family are Majestouch? And Cherry G80-3000s?
Thanks
A long space bar... what a waste of space!
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #1 on: Fri, 04 December 2009, 08:47:15 »
I'd say DCS for G80-3000.
Offline itlnstln
« Reply #2 on: Fri, 04 December 2009, 09:13:27 »
Filco seems to have the KT set, I think.
Offline spremino
« Reply #3 on: Fri, 04 December 2009, 09:53:10 »
I'd say DCS for both.
Offline itlnstln
« Reply #4 on: Fri, 04 December 2009, 10:01:08 »
No, there is no difference in keys by row.  On the Filco, you can swap the X and T keys and never know the difference (other than the legends).
Offline itlnstln
« Reply #5 on: Fri, 04 December 2009, 10:11:57 »
I just pulled a top row and bottom row key, they are the same.  I am using the blank key set, but I don't think they are different than the stock ones, though.
Offline itlnstln
« Reply #6 on: Fri, 04 December 2009, 10:13:02 »
TBH, none of these really look exactly like the Filco keys.
Offline timw4mail
    • https://timshomepage.net
« Reply #7 on: Fri, 04 December 2009, 10:34:55 »
I've got a blank set of Filco keys on my Scorpius, and looking at it right now, it's definitely DCS.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline itlnstln
« Reply #8 on: Fri, 04 December 2009, 10:39:24 »
Weird. I either got a bad set, or they changed at some time. I took a look at the original keys, and they are DCS.
Offline itlnstln
« Reply #9 on: Fri, 04 December 2009, 11:36:52 »
Or maybe I'm just getting blinded by the light reflecting off teh shinee.
Offline itlnstln
« Reply #10 on: Fri, 04 December 2009, 11:52:23 »
Do you wash you hands in battery acid?
Offline alpslover
« Reply #11 on: Fri, 04 December 2009, 12:10:21 »
Quote from: itlnstln;138715
they must be different then, because zx
Offline alpslover
« Reply #12 on: Fri, 04 December 2009, 12:13:52 »
i just pulled the stock keycaps off a tenkeyless and the alphanumeric rows are all different from each other.  however, the function key row is the same as the number row, and the very bottom row (ctrl, alt, space bar) is the same as the bottom alpha row (zxc, etc.)
(edit note:  just saw your other reply and the filco is close to dcs but not exactly, as the function key row isn't unique.)
« Last Edit: Fri, 04 December 2009, 12:15:53 by alpslover »
Offline spremino
« Reply #13 on: Fri, 04 December 2009, 13:13:40 »
Quote from: ripster;138787
Spremino - were you just curious or thinking of key swaps??
Thanks for the pics, Ripster.
I'd like a blank (Otaku) keyboard. I currently own a Filco set, but after seeing my Tenkeyless going shiny, I'm going to buy some quality sets straight from some keycap manufacturer here in Europe. Since it's likely I'll have to buy more than one set, I wonder whether I could manage to order sets which would fit both Filcos and Cherries, therefore increasing their "resell-ability".
Offline itlnstln
« Reply #14 on: Fri, 04 December 2009, 13:24:25 »
Quote from: ripster;138809
I'm not sure about the front row on the Cherry Corp keyboards even if they have the Windows key being swappable - on the POS boards the keys are mounted off center. Otherwise you should be able to swap away.
Looking at some of the keys on the 'boards we just got, the larger keys are mounted dead center.  I will need to check my G80-3000 to see if they are the same way.
Offline spremino
« Reply #15 on: Fri, 04 December 2009, 13:34:46 »
Yes, I'm aware I'll likely have to order keycaps to fit the bottom row of both keyboards. A few keycaps more will not be an issue. OTOH, from your Anti-Otaku article, I understand that upper keycaps of Majestouch and Cherry are sized alike.
Offline lowpoly
« Reply #16 on: Fri, 04 December 2009, 13:55:32 »
Cherry keycaps don't fit any row in the original post. Rows 0 (fn) and 1 have the same slant as have rows 4 and 5 (spacebar).
Offline spremino
« Reply #17 on: Fri, 04 December 2009, 14:11:04 »
Oh, I missed TheSoulhunter's post about KBC keycaps. I think I'll go with them (easier).
Thanks all for your replies.
Offline nanu
    • http://T-T.be/portal
« Reply #18 on: Fri, 04 December 2009, 14:47:48 »
For the useless record, I measured these angles for Filco keys:
-2° esc/F row
-2° numbers row (same profile as top row)
 1° qwer row
 6° asdf row
<11° zxcv row
<11° space row
« Last Edit: Fri, 04 December 2009, 14:59:17 by nanu »
Offline AndrewZorn
« Reply #19 on: Fri, 04 December 2009, 15:38:50 »
wow good post
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #20 on: Fri, 04 December 2009, 15:50:05 »
The keys on my Focus are sculpted like that too. I think I will measure their angles sometime and report to you all on it soon.
