Author Topic: V60 dead or am I doing something wrong?  (Read 2206 times)
Offline Geroximo
« on: Mon, 22 February 2016, 04:50:08 »
Hi,
I got my KPB V60 today. It's my first ANSI keyboard.
The problem is:
When I plug it in, nothing happens, it doesn't work.
It pops up in the device manager as USB-HID Keyboard, but dissappears again quite fast.
Am I doing something wrong? Do I have to change settings when switching from ISO to ANSI layout?
Do i miss something special about this keyboard?
Or is it just broken?
Regards
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: V60 dead or am I doing something wrong?
« Reply #1 on: Mon, 22 February 2016, 05:00:53 »
Hi,
The problem is:
Regards
If this doesn't happen with any other keyboard I'm thinking you might have to RMA. Have you tried other USB sockets? Perhaps you found a dusty socket.
Maybe someone else knows something about the KBP v60 that I don't.
Offline Geroximo
« Reply #2 on: Mon, 22 February 2016, 05:13:33 »
I tried different cables, but all cables work with my Poker but none with the V60.  :(
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Mon, 22 February 2016, 05:17:20 »
That sounds, less than ideal.
Offline Geroximo
« Reply #4 on: Mon, 22 February 2016, 09:13:22 »
Oh my god ...
It works! I have no idea how and why, all I did was letting the keyboard sit a few hours and now it actually works.
Maybe it was too cold and needed to get to room temperature first .. I don't know.
Damn, and I already opened a RMA ticket on Massdrop  :-X
Offline kolyz
« Reply #5 on: Mon, 22 February 2016, 09:18:51 »
Definitely keep an eye on it, the v60 should be plug and play.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #6 on: Mon, 22 February 2016, 12:15:37 »
Did you leave it outside for a little bit? Aside from being iced over, or snowed on, that keyboard should be able to withstand inside ambient temperatures. :/
Offline merlin64
    • MechMerlin
« Reply #7 on: Mon, 22 February 2016, 13:07:55 »
I would still RMA it. You don't know what intermittent issues can occur in the future.
