Author Topic: Olivetti ANK 27-101  (Read 3769 times)
Offline spike03
Olivetti ANK 27-101
« on: Mon, 22 February 2016, 14:40:34 »
What are your thoughts on this keyboard, I have the opportunity to get it for $3, is it worth it? Olivetti ANK 27-101
Re: Olivetti ANK 27-101
« Reply #1 on: Mon, 22 February 2016, 14:48:14 »
Probably Olivetti dome, so crappy.
Offline vivalarevolución
« Reply #2 on: Mon, 22 February 2016, 21:53:30 »
Actually, I used that in France.  Probably one of the best rubber dome boards I have used. Tactile and light, but somewhat soft.  I honestly thought it was a mechanical switch underneath.
Offline jonathanyu
« Reply #3 on: Mon, 22 February 2016, 23:33:39 »
get it, don't wait. you can't even buy a crappy dell rubber dome for $3, and this is even olivetti.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Tue, 23 February 2016, 02:16:02 »
As far as domes go this one is pretty good really, but they're still domes of course.
Offline spike03
« Reply #5 on: Tue, 23 February 2016, 02:34:28 »
Thanks for the advice! I'll buy it, for $3 I can't go wrong! :thumb:
Offline jamster
« Reply #6 on: Tue, 23 February 2016, 06:36:22 »
You had to ask the internet for an opinion on spending $3?
Offline spike03
« Reply #7 on: Tue, 23 February 2016, 10:38:32 »
Do you have a problem with that? It wasn't about the money specifically, I was curious about the keyboard and its value, that's what I came here to ask the experts.
Offline TalkingTree
    • My projects
« Reply #8 on: Tue, 23 February 2016, 15:28:25 »
I own the ISO version of it and it's actually slider over dome, and not a bad one.
