Author Topic: 3d printed keycap durability  (Read 6181 times)
Offline The Mick-a-nator
« on: Tue, 23 February 2016, 05:08:01 »
Does anyone have 3d printed keycaps for flair? I wonder how they stack up against regular ABS/PBT keycaps in terms of lifetime, especially the powder deposit printed plastics like Shapeways use. Do they cope with being pulled off or (heaven forbid) rough treatment?
Offline Pdub
Re: 3d printed keycap durability
« Reply #1 on: Tue, 23 February 2016, 05:39:27 »
I print my masters from shapeways. I have sold some 3D printed caps too. They hold up just as well as other caps if designed correctly. It's almost a none argument of quality. Some people just don't seem to be fans. Also you have to be careful with 3D prints. Not everyone does a good job with the stems.
Offline 27
  • The Maple Man
« Reply #2 on: Tue, 23 February 2016, 07:38:24 »
The issues with the stems are usually people failing to account for warping and growth.
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
« Reply #3 on: Tue, 23 February 2016, 08:19:32 »
Could you expand on this a little? I want to try and print a keycap but I don't want to make a dud.
Offline 27
  • The Maple Man
« Reply #4 on: Tue, 23 February 2016, 08:23:30 »
It's all trial and error for that. Different materials and methods have different tolerances, and will behave in different ways. Even 0.2mm can make the difference between a tight or loose stem.
Offline KeypressGraphics
  • Dare to Dream
    • Keypress Graphics
« Reply #5 on: Sun, 28 February 2016, 06:39:49 »
My experience is that 3D-printed Nylon keycaps are almost indestructible. Frosted plastic can be fragile if dropped, but will be completely durable under normal keyboard use unless the design itself is particularly delicate - like say there are tiny, tiny antennae on an insect's head which can be snapped off, that sort of thing.
Generally both materials will hold up as well as ABS or PBT I would think.
May all your key presses strike true.
  Choc Mini         HHKB
Offline Tangtawan
« Reply #6 on: Wed, 02 March 2016, 11:02:10 »
i have a 3D printed keycaps, and i feel that its much more stronger than even thick PBTs; but it depends on the materials you're using as well.
I have Zortrax M200, and i use this Z-Ultrat material. Its designed to be a working part in machine; so i guess its durability should be beyond any regular keycaps.
https://zortrax.com/products/z-ultrat-new-filament-from-zortrax/
My boards : Model F AT (6450200), Industrial M (1394950), Model M SSK (1391472), Model M13 (13H6705), Model M (1390131), Focus FK-2001 (ALPS SKCM Blue), HHKB Pro 2, Realforce 87U 55g, KBP V80 Matias Click, TADA68 (Gateron Reds), Filco Majestouch 2 TKL (67g Ergo Clears), Cherry G80-11800 (Ergo Clears), KBT One 108 (MX White), Ducky One TKL RGB (MX Black), Filco Majestouch Tenkeypad (MX Brown), Leopold FC210TP (MX Red)
