Author Topic: GH60 - Coming Soon  (Read 90536 times)
Offline i3oilermaker
  • * Moderator
  • techkeys.us
    • TechKeys
GH60 - Coming Soon
« on: Tue, 23 February 2016, 09:47:17 »
Coming Soon (tm)
129264-0129266-1129268-2
Re: GH60 - Coming Soon
« Reply #1 on: Tue, 23 February 2016, 09:55:00 »
Alps?
« Reply #2 on: Tue, 23 February 2016, 09:55:37 »
Alps?
Nope. PCB doesn't have holes to accept it in OP. Nor did the OG GB have Alps compatibility.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #3 on: Tue, 23 February 2016, 09:56:29 »
Coming Soon (tm)
Another 60% offering  :thumb:
Everything comes pre-soldered (smd/diodes)?
Is this the final version though?
Nevertheless, good offerings!
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #4 on: Tue, 23 February 2016, 09:57:35 »
Does this mean I can buy GH60 PCB from techkeys and get it before my groupbuy order from almost 3 years ago?  :p
I keeeed I keeeeed.
Is Rev C version newer or the same as the original group buy?
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #5 on: Tue, 23 February 2016, 09:59:56 »
Coming Soon (tm)
Final version - same as GB - rev c is the latest
Everything but the switches is pre-soldered
« Reply #6 on: Tue, 23 February 2016, 10:06:52 »
Nice! Happy to see these becoming available.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #7 on: Tue, 23 February 2016, 10:19:21 »
Coming Soon (tm)
Heh, nice nice.
I have one question and regarding the switch placement for "esc" , "1" and "enter".
Are they upside down accidently? Seems like the leds placement is opposite compared to the other switches. o.o
« Reply #8 on: Tue, 23 February 2016, 10:32:01 »
Coming Soon (tm)
Heh, nice nice.
It's to accommodate other layout options, or to route the traces around electrical components.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #9 on: Tue, 23 February 2016, 10:33:35 »
Coming Soon (tm)
Heh, nice nice.
Ah alright, I thought it was an accident. Thanks for the clarification!  :)
Offline Happylomo
« Reply #10 on: Sun, 29 May 2016, 00:12:25 »
Hey, does this rev. C support full in-switch LEDs? Because if i remember correctly in rev. B, it only supports the WASD, and several other keys.
« Reply #11 on: Sun, 29 May 2016, 00:31:02 »
Are these likely to be available in sufficient quantities to last for a while?
Quite a few new members say they'd like to build their own keyboard, and it would be good to be able to point them to TechKeys for the GH60, provided there's enough stock to last for a while.
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #12 on: Sun, 29 May 2016, 15:20:20 »
There is currently a fair amount of stock - I don't foresee selling out any time in the near future
« Reply #13 on: Sun, 29 May 2016, 21:40:19 »
Will the kit include all parts (including switches)?
Will there be an option to purchase a kit pre-assembled?
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #14 on: Mon, 30 May 2016, 00:09:07 »
Right now only the PCB is available: http://techkeys.us/collections/accessories/products/gh60
I have plans to add more switch options, stabilizers, and plates.
I do not have plans to offered a pre-assembled option
« Reply #15 on: Mon, 30 May 2016, 05:39:37 »
Cool, thanks :)
Switches are easy, stabilisers not too difficult, and there's probably a plate or two would suit.
There's probably a few suitable cases around too.
Good luck i3oilermaker, and if anyone asks, I'll be sure to point them in your direction :)
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #16 on: Tue, 31 May 2016, 22:46:55 »
Plates, Stabs, Cases, and more switch options are coming soon.
Offline ricyuyc
« Reply #17 on: Fri, 03 February 2017, 21:26:50 »
Hi, I checked at web store that the ver.C PCB have been sold out, will it be re-stock in coming and any preliminary schedule? Thanks.
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #18 on: Mon, 06 February 2017, 11:19:56 »
Yes - prob about 2 weeks out.
Offline shekki
« Reply #19 on: Wed, 28 June 2017, 22:06:43 »
Any chance we'll see more black colored versions in stock?
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #20 on: Thu, 06 July 2017, 15:55:29 »
At some point yes - but it will likely be a while.
Offline Marutks
« Reply #21 on: Sat, 29 July 2017, 12:22:11 »
Is ANSI "enter" key switch upside down too?
