Author Topic: [IC] High Contrast Keyset DSA (SA is possible) - Updated with Render 2/24  (Read 6398 times)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
I posted this on Reddit and received some feedback for it. I should have checked here first  :-\
Edit - Updated with SP's Double Shot ABS palette
Caps - NN/BBQ/RCR/YCE  legends - BBQ/NN
 Caps - NN/BBQ/RCR/YCE  legends - WFK/NN
Caps - NN/BBQ/RCR/YCE  legends - YCE/NN
« Last Edit: Wed, 24 February 2016, 05:21:10 by csmertx »
Re: [IC] High Contrast Keyset
« Reply #1 on: Tue, 23 February 2016, 15:28:31 »
Yuck. This is super gross.
Just kidding. It's nice. I've seen it before.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Tue, 23 February 2016, 15:49:49 »
Hehe. Thank you  :p
Offline simonyunhe
Re: [IC] SA High Contrast Keyset
« Reply #3 on: Tue, 23 February 2016, 19:20:35 »
SP don't do SA PBT double shot, so I guess this one is abs, right?
KeyBs:|RS96-Brown|GS-87-White|DIYer60-Red|VA68M-Brown|GS-ALT71-Blue|IKBC-108-Black|
KeyCs:|SA Carbon R1+2|SA Camping|SA Amazing Chocolatier|SA Commando 88 Ghost|SA Hyperfuse|SA Penumbra|SA Doom|SA Creamy Orange|SA Ocean Dolch|SA Lotus*72|SA Trouble Minds R2|DSA Granite|GMK TA|GMK Soware|XDA Mailstone|GM Ember|
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4 on: Tue, 23 February 2016, 20:27:57 »
For real? Thank you, how about dye-sublimated? If not I could switch to the ABS palette. I'm really new to all of this :-[
Offline simonyunhe
« Reply #5 on: Tue, 23 February 2016, 20:35:57 »
Sorry, ABS is only option for SA profile now, SP do not do SA PBT dye sub and even they do there is also no way to dye sub white on black. Dye sub require dark color on light color, black on white for example.
« Reply #6 on: Tue, 23 February 2016, 20:37:26 »
They don't do PBT SA yet. Or, rather, they have but it was a very limited run. I know there are people right now trying to get them done, but it's a work in progress.
If you really want to go with SA, your only option is doubleshot ABS.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7 on: Tue, 23 February 2016, 20:49:21 »
Fair enough, I'll make the adjustments. Man, I was really pulling for dye-sub on this one. I'll update with a proper render, thanks again for the help
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: [IC] DSA High Contrast Keyset - Updated with 3D Render 2/24
« Reply #8 on: Wed, 24 February 2016, 01:06:59 »
Added a 3D render, and changed the title of the thread from SA High Contrast to DSA High Contrast. I bet that is a common rookie mistake, I definitely wont make that mistake again.
I just do not have the experience necessary to know if SP does DSA dye-sub group buys so I will leave it as double shot abs for now.
If there is an interest I can take notes and make alternate modifiers/layouts etc. I like this keyset design, but I also like a lot of strange things.
Offline Oobly
« Reply #9 on: Wed, 24 February 2016, 01:31:27 »
SP can do dyesub PBT DSA and DCS, but you can't dyesub a light colour onto a dark base, so your only option is doubleshot ABS for these colours, but that also means you can use any of the three profiles, SA, DSA or DCS. the choice is yours :)
A lot of people (myself included) don't like typing on DSA profile and many don't like how thin DCS is and the sharp angle of the bottom two rows, so if you're looking for a larger number of sets sold, then SA is the best option if you go with SP. Otherwise there's GMK who are now accepting more community group buys, but they have a very limited set of ABS colours to choose from and a high MoQ (see pic), whereas SP have a nice huge selection. Also less open to doing custom legends than SP.
129365-0
This has all just reminded me to get my stuff together and post the articles I've been preparing which explains all this stuff for prospective new designers... It's not fair to expect new people to simply know all this.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #10 on: Wed, 24 February 2016, 03:40:38 »
Aha, ABS it is then. SA would be my first choice, I have a model downloaded and ready for tweaking. I guess I'll hold off on the SA renders for now and see if the High Contrast set gains any momentum. Cheers
Re: [IC] High Contrast Keyset DSA (SA is possible) - Updated with Render 2/24
« Reply #11 on: Wed, 24 February 2016, 13:00:37 »
So Easterly delicious.
Offline Chewypost
  • Bacon PanCAAAKES
« Reply #12 on: Wed, 24 February 2016, 13:06:02 »
Do you not like the feel of DSA? Is it too flat compared to SA? And what's the real difference between ABS and PBT? I've had ABS Caps before and they just seem so thin and light
Hana DSA - Duck Octagon V2| Ducky Mini - MX Red
_____________________________________
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #13 on: Wed, 24 February 2016, 19:02:02 »
Cheers  ;D
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #14 on: Thu, 25 February 2016, 20:14:16 »
Edit - 2/25 Thread locked. I didn't know about the hoff set when I created this  :cool:
