Author Topic: Ergodox diode messed up?  (Read 2436 times)
Offline strigif0rm3s
« on: Thu, 25 February 2016, 09:34:24 »
I sort of screwed up (broke it off)  the plate where the diode gets soldered on. So i soldered it a bit further over to make the connection. Will this still work or am I screwed?
Re: Ergodox diode messed up?
« Reply #1 on: Thu, 25 February 2016, 09:35:26 »
I know that's a crap job (the others look good) but I tried to fix it and made it worse....
Offline merlin64
    • MechMerlin
« Reply #2 on: Thu, 25 February 2016, 14:27:47 »
I don't think you'll be able to tell by just visual inspection. Get a multimeter and check it out. If anything get a toothbrush and some isopropyl alcohol and clean it up.
Offline KaminKevCrew
« Reply #3 on: Thu, 25 February 2016, 14:31:39 »
The diode may be burnt. I happen to have about 2500 SMD type diodes here, so if you need one or two, I could send them to you for the price of shipping (might be better to just buy a bunch on ebay though, since they are dirt cheap anyway...)
« Reply #4 on: Thu, 25 February 2016, 14:31:58 »
OK thanks for the help. That's the same connector though right? For the through diode and the plate diode?
« Reply #5 on: Thu, 25 February 2016, 14:36:13 »
My diodes are the plate style, although they look a bit different (the ones I have are the same style that GON and winkeyless use)
I will have some through hole diodes that I would send, but they are still in transit from China, so I have no idea when they will actually get here... XD
« Reply #6 on: Mon, 07 March 2016, 12:09:06 »
it works!!!!!! Only had to resolder 2 diodes. Easy and then all the keys worked. Bam! So pumped.
Cherry MX Brown switches.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #7 on: Mon, 07 March 2016, 12:14:06 »
Glad you got it working. You can also test your diode(s) with a simple multimeter, you should only get a voltage reading in one direction ( + -). If your multimeter shows a voltage reading in both directions, your diode is bad.
« Reply #8 on: Mon, 07 March 2016, 12:15:27 »
It was the soldering job (me!) not the diode. Thanks though!!!!!!
