Author Topic: Using seil to remap macbook pro keys  (Read 2379 times)
Offline 1swt2gs
  • DOGE
« on: Sat, 27 February 2016, 00:12:03 »
I didn't know where else to post this, so hopefully someone can help me out on here!
I can't for the life of me figure out how to remap fn on seil. Ideally, I need to change fn -> left control & left command -> left alt
I selected the option:
Change command_L 55 (left command) to keycode 58 and succesfully left command is now left alt.
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline daerid
    • Rossipedia
Re: Using seil to remap macbook pro keys
« Reply #1 on: Sun, 28 February 2016, 11:49:45 »
You're going to need Karabiner for that (which used to be called KeyRemap4Macbook). It's a much richer utility than Seil, and ofters a ton more customizations.
It's also made by the same developer, and both can be installed simultaneously without problem.
Offline 1swt2gs
  • DOGE
« Reply #2 on: Sun, 28 February 2016, 13:45:29 »
Thanks for the info! Downloading it now!
