Author Topic: Pok3r and symbols: is there a way?  (Read 1501 times)
Offline AwSmCreator
« on: Mon, 29 February 2016, 04:36:00 »
Hey there! So I have a few different keyboards but my daily carry to work is my Pok3r with browns. Love it, but I would like to also be able to input symbols. For example, the degree symbol, is there a way I can either make a program on the board to input the symbol or reprogram keys to allow me to input a command to create the symbol? Thanks for your help!
Re: Pok3r and symbols: is there a way?
« Reply #1 on: Mon, 29 February 2016, 05:05:47 »
The degree symbol is not part of the normal ANSI layout, so you must change the layout in your _OS_ to e.g. german layout (it's on the Esc key of your Poker, you get it with <shift>+<Esc> or <Fn>+<Esc>) .
Offline AwSmCreator
« Reply #2 on: Mon, 29 February 2016, 05:41:40 »
I'll try this out, thank you for the info!
