Author Topic: Vortex Poker 3 and Programmers Dvorak Layout  (Read 3342 times)
Offline overthetop
« on: Tue, 01 March 2016, 03:22:41 »
Hey Guys,
I'm planning to buy Vortex Poker 3 but I worry that because of the layout it will not work properly with Programmers Dvorak Layout and I'm using it. Can someone that has that keyboard check it out and tell me whether it's working. Besides the numbers and the special symbols like [(*]...and I'm wondering whether the arrow keys are working properly.... I'll appreciate it.
« Last Edit: Wed, 02 March 2016, 03:41:23 by overthetop »
Offline Liocer
Re: Vortex Poker 3 and Programmers Dvorak Layout
« Reply #1 on: Tue, 01 March 2016, 15:31:57 »
Hey Guys,
I'm planning to buy Vortex Poker 3 but I worry that because of the layout it will not work properly with Programmers Dvorak Layout and I'm using it. Can someone that has that keyboard check it out and tell me whether it's working. I'll appreciate it.
Out of the box no, it won't support it but... You can reprogram the whole thing with enough patience. The only issue is that a fw update will wipe out all of your hard work :/
Offline Perish
    • Killscreen
« Reply #2 on: Tue, 01 March 2016, 16:25:36 »
Hey Guys,
A dev's derivative of Dvorak. Thats pretty niche. How do you deal with QWERTY boards? Or do you just carry a Dvorak board around with you and plug it in when you need to?
Offline overthetop
« Reply #3 on: Wed, 02 March 2016, 03:16:00 »
The only way to know for sure whether it's working on Poker 3 is to turn on Programmers dvorak and try (it's installed by default on linux and for windows machines it can be installed from that link). @Liocer is this the way you have concluded that it's NOT working?
Offline overthetop
« Reply #4 on: Wed, 02 March 2016, 03:26:51 »
Well I don't deal with qwerty anymore. You can configure Dvorak on any machine within a minute (it comes with the default installation), so it's not a problem. It's a software configuration.
« Last Edit: Wed, 02 March 2016, 03:28:43 by overthetop »
Offline Liocer
« Reply #5 on: Thu, 03 March 2016, 14:19:15 »
Actually I was saying that you could change the bindings on the hardware to be whatever you want regardless of software. So yes you can def get it working.
Offline overthetop
« Reply #6 on: Fri, 04 March 2016, 11:00:14 »
Yeah I know but I don't want to use the DIP switch. I need to work out of the box with the original software for the layout. Do you have that keyboard with you? Can you change your layout and check whether it's working?
Offline overthetop
« Reply #7 on: Sat, 05 March 2016, 00:34:26 »
Anyone with Poker 3 here? Come on guys...
