Author Topic: Salutations Keyboard People  (Read 1871 times)
Offline MehStrongBadMeh
« on: Tue, 01 March 2016, 21:50:43 »
Greetings,
I am MehStrongBadMeh, and I am no stranger to mechanical keyboards. I have amassed a small collection of mostly vintage keyboards. This includes a good old Model M, a bizarre NEC APC-H410E, a cute little Cherry G84-4100, and another Model M that I refurbished and modded into a blank, black, usb keyboard. In addition, I found an old Dell AT101W in the back storage room of where I work and use that as my work keyboard. My main, however, is a Corsair K95 RGB with Cherry MX Blue switches. I have replaced the G-keys with transparent relegendable keycaps and I am slowly replacing the F-row with transparent artisan keycaps based around around a robot/armor/tech theme. I like lighting them up in whatever color I choose using the RGB lighting. I eventually plan to replace its full keyset after it starts to wear down (I have some ideas for working around the bottom row). I prefer clicky switches, like the Cherry MX Blues and Buckling Springs.
Recap of boards mentioned:
  • IBM Model M - Buckling Spring
  • IBM Model M (modded) - Buckling Spring
  • NEC APC-H410E - NEC Oval Blue
  • Cherry G84-4100 - Cherry ML
  • Dell AT101W - Alps Complicated Black
  • Corsair K95 RGB - Cherry MX Blue (pictured below)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Salutations Keyboard People
« Reply #1 on: Tue, 01 March 2016, 22:13:56 »
Man, kudos for the homestar runner theme
« Reply #2 on: Fri, 04 March 2016, 04:26:47 »
Welcome to Geekhack!
A very nice collection you have :)
I have an NEC APC-H4100E, which is basically the same as the APC-H410E, maybe regional difference or something.  Interesting the way it actuates BEFORE the click.
If you like buckling springs, have you tried MX green switches?  Just like blues, but much stiffer :)
