Author Topic: Custom Cable: Fill the gap between Case and Cable  (Read 2824 times)
Offline Kalp1
« on: Wed, 02 March 2016, 10:38:46 »
Hello,
So I've made a custom Cable for my filco.
How did you manage to fill the gap between the hole in the case and the cable ?
Used some heatshrink, but It doesn't feel really solid and reliable.
In other word: How do you replace this ? (and how do you call it?)
« Last Edit: Wed, 02 March 2016, 10:45:28 by Kalp1 »
Re: Custom Cable: Fill the gap between Case and Cable
« Reply #1 on: Wed, 02 March 2016, 12:09:14 »
Option 1 - carefully slit the rubber piece pictured and glue it on the bottom of the cable out of sight.
Option 2 - make a replacement out of Sugru :)
Offline Kalp1
« Reply #2 on: Wed, 02 March 2016, 13:38:28 »
I think I'll go for this one, even if it make a big gap when I put it back on the larger cable's diameter.
« Reply #3 on: Wed, 02 March 2016, 16:25:58 »
In English it would be called a rubber grommet.
Hardware stores sell them, usually for plumbing purposes. If both ends of the cable already have attachments, you will have to cut it.
- D Trump 2026-10-24
Offline Kalp1
« Reply #4 on: Thu, 03 March 2016, 18:32:11 »
Thank you, would never thought that a "grommet" could make the job.
